Rut
I picked up my frame from the shop after sandblasting and powder coating and really like the work they did. I want to have the lower fulcrum brackets powder coated as well, but I don't know if it will leave room for the poly bushings I plan on installing. The brackets came from TRF by way of Revington I believe and on two the studs are straight and parallel and on the other two they are not. Is this correct and should I powder coat?
Thanks, Rut
Thanks, Rut
