I'm soooo dumb. I did not check the rear wheel cylinders before trying to fix the breaks on my 73 B GT. Tonight I decided to pull the brake drums and have a look after borrowing a mityvac from a neighbor. The Vac would not get any fluid out of the passenger rear cylinder. I pulled the drum and founf enough fluid to indicate this is where one problem is located. Will rebuild cylinder and try to bleed brakes.
What a dumby!!! Two weeks of work and I did not pull the drums. Auggggh. /ubbthreads/images/graemlins/crazyeyes.gif
