Got_All_4
This is crazy. Rebuilt my steering column new switches and push connectors, new hazard relay and had everything working perfectly. Then tonight getting ready to button everything up and the turn signals stopped working. Traced wires and I have power to the flasher unit dark green wire but when I check the green brown wire where it comes out of the harness on the driver side no power. Even if I take the flasher out and put a jumper wire in still no juice. Now I ran a hot wire to the green brown wire that goes into the column switch and wired in the flasher and it all worked. Should mention that the 4 ways still work. So how can or where could I have lost a connection between the flasher unit and the harness under the dash?
Hi Guest!
