19_again
I just installed a rebuilt tranny from Quantum, I followed the Bentley steps all through the process, removing the engine and old unit and reinstalling the new assembly. Today I filled the tranny with fluid and when I tried going through the gears for the first time I had no clutch pressure. I pressed the pedal down a few times and got complete resistance at the top of the stroke, seemed more like a mechanical stop than the normal pressure you feel from good pressure when pressing the brakes. Upon feeling this unusual pressure I checked the system and found I hadn't completely set the slave boot in place. I took care of that, checked the local nuts and bolts while I was under there and tried the pedal again. This time it went straight to the floor every time, no resistance. Plenty of fluid in master, didn't touch the master during the work. I'm surprised there wasn't a gasket at slave connection as there was a drop of fluid on the low point of the slave. Any suggestions?
Mike
Mike
