sparkydave
My 1500 engine has had a strange problem ever since resurrecting it 2 years ago. Whenever I make a hard stop, the oil pressure drops almost to zero. I replaced the oil pan last year since it was rusting badly and had a dent in the bottom, but when I looked inside, the oil pump pickup is not bent or damaged, and the full mark on the dipstick seems to be a ways up from the bottom of the pickup. My guess is the oil is sloshing forward and uncovering the intake, but does anyone else's 1500 do this? I'm reluctant to just put more oil in since I don't want the crank to splash in it, but the oil pressure is fine otherwise. It gets 50 PSI at speed and never gets below 20 at idle. Just curious, since it is a little unnerving to see it going way down and then jumping back up when I'm stopped. I keep the oil at the upper mark on the dipstick, and as far as I know the dipstick isn't bent, damaged or the wrong one. It takes 4 quarts to fill it up that far when I do an oil change.
-Dave
-Dave
