Roscoe--
Correct on both accounts. When I fished the first pieces out of the oil I had drained in a routine change I was perplexed as the stuff seemed like hard plastic and I could not think of anyplace where plastic was used inside the engine. Upon dropping the sump I bigger pieces some of which resembled segments of a belt and things began to add up.
I took the opportunity to replace the timing chain as well and since there is no adjustment or tensioner for it getting the camshaft gear back into place was no mean feat.
