TR2/3/3A Loose Lift the Dot Stud
jfarris
Greetings,
The LTD Stud pictured below is lose on my TR3.
Is there a nut behind it or another way of tightening?
Do I have to remove the interior panel to get to the back of it?
Thanks.
Deleted member 8987
Been a long time since I had to mess with those. Dash and top of doors is wood screw threads, I think, the one you are questioning should be nut-on-back.
I would not try to spin the stud down hoping to catch the nut, as I do believe you'll fratz the paint.
Pull the inner panel loose enough to get into it with an ignition wrench. Braille capabilities might be in order. Pulling the entire panel will give you more access, more visibility. Hold the stud while doing it...again, long time ago for me...I think I pushed a piece of vacuum hose over the stud rather than a wrench.
Somebody else will have done it more recently.
TR3driver
Great Pumpkin - R.I.P
I agree, it's a nut. PITA to access even after you've removed the panel (and the soft top bows to get the panel out). You have to reach upwards through a cavity to reach it, and it cannot be seen unless you stand on your head inside the car. Most likely someone dropped the lockwasher repeatedly (BTDT) and finally installed the nut without it.
I would try spinning the stud, on the off chance the nut will hold against the inside of the panel instead of spinning with the stud. But my paint job is strictly a "10 footer", so I don't obsess over tiny scratches. ISTR it was hard to find a socket to fit the stud as well; it doesn't appear to be a standard size in SAE, Whitworth or metric.
STeve 1958
A friend of mine (I would never admit to doing this myself) could only get it hand tight. A single drop of super glue solved the problem.
Other idea is to put a vise grip on the stud and pull on it while you turn. Sometimes that will get the nut to engage. Could mess up the paint though.
sp53
I like that vacuum hose on the stud idea. I wonder if you could use the hose idea and then grip that with some plyers and pull back and up a little and the get the nut to catch, kinda synthesizing DOC and Randall’s idea. Those studs come in a verity of styles often a 9 mm wrench will catch that very little flat spot on the stud, and I put some blue tape on the flat side of the wrench for protection. I usually put a nylon washer under them also for fear of grinding the paint off as it tightens.
steve
DavidApp
Checking one of the remaining New TRF stud nuts I found that it was 1BA not 2 BA like the old studs and nuts that came with the TR3A.
I think I put a small drip of blue locktite on the threads.
David
jfarris
jfarris
Thanks for all the hints. I could get to the nut on the back of the stud, but could only hold it by hand. I tightened slightly from the outside. It appears there is no lock washer on the back. I have some spare studs. When it comes loose again, I'll put in a new one with a nylon washer on the outside and lock washer on the inside - maybe a little blue loctite to boot.
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
M Loose Pilot Bushing Spridgets 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
SherpaPilot TR6 Steering Column Loose Triumph 8
B TR6 Boot lid thread plates loose in stiffener Triumph 1
NutmegCT T-Series Loose valve cover oil cap MG 4
Lin Post in float bowl came loose Austin Healey 6
sparkydave Zenith auto choke coming loose Spridgets 3
tinman58 General TR It was just a loose wire Triumph 15
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
R water temp bulb loose Austin Healey 27
G Loose lugs on rear hub Austin Healey 7
S TR4/4A TR4A Water pump pulley loose Triumph 10
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T General Tech How loose can a piston liner be? Triumph 2
rustbucket Loose spokes on wire wheels MG 8
angelfj1 TR2/3/3A TR3A - Dynamo Fan is loose! Triumph 3
G 6 steering column loose Triumph 3
J What tool to get the nut loose on the steering box Austin Healey 5
jjbunn E-Type Turn Switch - loose braid for horn? Jaguar 6
Jim_Gruber Bottom Starter Motor Bolt - How do I get it loose? Spridgets 7
davester Loose manifold to exhaust connection MG 3
Johnny Door handle on BN7 came loose. Austin Healey 8
D Sway bar - BT7 - loose captured nuts Austin Healey 18
M TR2/3/3A Loose wing beading TR3A Triumph 4
D TR6 Loose TR6 Sunvisors Triumph 11
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
M Fuel Line Came Loose; Yikes! Spridgets 4
M TR2/3/3A 55 tr2 loose on I 70!! Triumph 3
CCURTISS T-Series MGTC Door Latch Backing Plate [screw loose] MG 0
Indnrdr Throttle pinch bolt came loose; how to get to it. Austin Healey 4
walshja winshield washer nozzle is loose Spridgets 20
71TR6 Loose rear view mirror Triumph 4
R Carburettor suction chamber cap loose - why? Austin Healey 23
charlie74 loose bonnet hinges Triumph 4
T Loose Nuts: Pedro-ized Triumph 19
A TR6 TR-6 Loose Handling Triumph 22
Woodie steering pinion loose Spridgets 18
P loose shift lever Triumph 7
simpzimmer wheel loose Triumph 4
R6MGS Ignition Switch loose.... Triumph 9
Thor Loose power at 3000 rpm's Spridgets 12
P Door Glass came loose... Spridgets 8
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
77_MG_Midget I think I have a screw loose!!!!! Spridgets 15
George Zeck Loose Front End .... Spridgets 6
D It was a loose alternator bracket... Spridgets 2
