TR4/4A looking to purchase 1965 TR4A have a few questions
AK_ED
Hello
New to the forum and hope to be a part of your comunuity
My name is Ed and im looking at purchasing a 65 TR4A, and my background is german cars, i have a couple of classic porsches and looking for a british car.the TR4, its green newer soft top, runs and drives usable interior as stated by the current owner. he tells me he has records from around the late 60s to current. im looking for the knowledge of you guys out there as im not sure where to focus when i go look at this car. i have done restos on old series rovers and know my way around the electrical and the carbs of the britt stuff.
i have seen pics of the car and it looks good in pics but going to look at it this weekend.
questions
1. is there areas of the car to pay attention to that are prone to rust,
2. is there areas on the frame that crack rust etc.
3. door gaps i have read that body mounts worn will make them uneven?
4. is there items known to these cars specific that are troublesome.
thanks guys and hope to be posting here more often with a new car to play with.
cheers ed
tdskip
Hi Ed - welcome!
Body / frame condition is the thing to watch. Mechanical bits and trim are all readily available with a choice of suppliers.
Look at front and rear fender bottoms, especially at the front since if those are iffy there will me rust in the rocker section that cover. Floors are usually at risk, as is the rear deck where the rear fenders met the cockpit area. Battery tray in engine bays typically go. In the engine compartment look at the inner fenders near where the fuses are as well.
Door gap can range from easily adjusted to indicating that the sills / structure is rotten. Gaps should be consistent but body fit on these cars isn't in Mercedes or BMW precision or a tight.
Rear of frames near the rear suspension can be a rust spot, check everything but start there.
A 65 should be a solid axle car.
If you post pictures here, as many as you can, we'll crawl through it visually for you.
These are fun and tough cars - you'll enjoy her.
Mickey Richaud
Welcome, Ed! The TR engine is one of the most reliable, and bullet-proof examples the British ever made. As Tom mentioned, rust is your enemy; check all the nooks and crannies. Adding to Tom's list, check around and under the master cylinders; prime area for rust-through.
Good luck!
Mickey
A
AK_ED
hey tdskip
thanks for the quick reply and the welcome!
i will study these areas when i look at the car, this is exactly the kinda info i was looking for. the owner mentioned that the door gaps where not square and that the body mounts would help to fix this?
but ill get some pics and post them up.
cheers ed
tdskip
3798j said:
Careful, 4A's were available with IRS right from the start (1965).
Fair point, maybe I should have said it is "likely" it will be a solid axle car. In any case as you determining the axle type you should look at the section of the frame there.
tdskip
Body mounts might help account for that, but don't bet the farm on it. If the car is otherwise solid then the gaps should be adjustable but don't expect them to be really tight.
A
AK_ED
sound good ill look it over and see what it looks like in person.
i hope its solid as he says it is because if so ill have a cool old triumph! :thumbsup:
ed
sail
:iagree:
Welcome Ed. Only around 7000 of the some 28000 4A's were solid axel (not a bad thing.) Solid axel is a little harsher ride, IRS has more parts to replace. 4A IRS shares much suspension with 250 and 6's. What they said to check. The first place I would look for rust on an IRS car is where the rear trailing arms attach to the frame towards the front or the spring on a solid axel.
Post pictures and be prepaired for a critique.
Cheers to you.
DanB
Hi Ed, and welcome.
I have owned my 66 TR4AIRS since 1980, when I bought it for $300. The biggest issue with an IRS model that was not mentioned earlier is the tendency of the pumpkin to break loose from the frame. There are 4 studs that come from frame where the diff is attached and the torque stresses them over time, so if you drive it, listen for a "clunk" from behind you. If you hear it, chances are one of the studs has pulled from the frame and will need to be welded. Check the frame for rust like Richard said. Mine had some stress cracks around the motor mounts and also where the front suspension attaches.
These are great cars, alot of fun to drive and really easy to work on. Parts seem to be more available now than they were back when I first got mine, mostly due to the internet.
Have fun and good luck!
Dan B.
South Charleston, WV
TR4nut
Welcome Ed-
Everything has been covered here very well, other minor add is check the frame mounts in the front suspension too. In the 4A, the original lower pivot mounts used 1 stud to mount to the frame, this was found to be a weak point and later TR6's went to 2 studs. Might check for frame issues there, or maybe even a conversion to 2 stud mounts which has been a recommended fix.
My guess is it is the same green 4A I saw on Craigslist about a year or two ago - can't be that many in Anchorage. If so, it did look very nice I think. Hope you get it, I'm heading up there in May on business and would love to see it on the road!
Randy
Geo Hahn
AK_ED said:
...looking for a british car.the TR4, its green newer soft top, runs and drives...
Ed --
The main thing to keep in mind when shopping for a TR4 in Anchorage is that you probably don't want this one:
Geez, I do wonder what became of that car.
Since rust is an issue anywhere (even in the deserts of Arizona) you've been given good advice to look very hard at that. Floorboards can be replaced but a look at them can be a good indicator of what is going on where it is harder to check.
Both my cars are solid axle examples so I cannot comment specifically on IRS but I believe there are some particular areas in the rear body pressing that are more vulnerable to rust on IRS cars.
Several books and buyers guides are available for these cars, in particular the one by Roger Williams is useful I think.
<span style="font-style: italic">I see no buyers guide on the VTR site for TR4s, but they do have one for TR250s which share the same set-up (other than engine) with the TR4A IRS:</span>
TR250 Buyers Guide
A
AK_ED
TR4nut said:
Welcome Ed-
Randy
Randy
it might be the same one but not 100% sure on that. it is available due to the fact im selling him a old single cab vw pickup. i just got off the phone with him and says that it is a rust free california car and car will be available for me to look over on saturday. i asked him about the troubled areas and he said he bought a book on how to buy a triumph, and went down the list and he was very aware of all the areas you guys have mentioned, he says the worst thing about the car is it leaks oil from the rear main seal. but i will post more info when i get it.
ed
A
AK_ED
Geo Hahn said:
Ed --
TR250 Buyers Guide
i would love to have this car even if crushed as man if it could only talk.
ed
TR4nut
Sounds like you found a very authentic Triumph then - that's not a defect, that's a quaint feature.
T
TRDejaVu
Welcome. All of the above, plus the rear fender top edge joints, especially where they are next to the center saddle panel (the one with the gas gap in the middle). If paint is bubbling in that gap then the saddle may need some work due to hidden rust.
I have a solid axle car and it is a blast to drive - power nothing; the most high tech part is my garage door opener. Power brakes are for weenies :smirk:
DanB
Ed,
It is not leaking. It's marking its territory.
But seriously, the rear main seal leaking is almost always caused by too much pressure in the crankcase, and this has been addressed on this very forum recently under a thread with PVC in it. Many folks go back to the earlier crankcase venting and road draft tube, but I put a catch can in mine that is doing the job pretty well so far.
Dan B
66 TR4AIRS EFI
80 TR7 DHC
A
AK_ED
DanB said:
Ed,
Dan B
66 TR4AIRS EFI
80 TR7 DHC
Dan
i read that thread and it makes sense ill inspect this when i get the car. i have talked with the owner again and mentioned that the seal was more of a wiper type seal and not the typical rubber. he mentioned it resembles an old vw seal? anyways im getting excited about looking at her and if the condition the owner says bringing it home.
cheers ed
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
B MGB Looking to purchase a green 67 MGB MG 10
G First post, Looking for info on AH 3000 purchase. Austin Healey 4
RickB 74 Midget - may purchase, looking for input Spridgets 27
R TR6 Spridget Guy looking to purchase a TR6 Triumph 17
L Looking to purchase a MINI British Motor Corp 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
