Looking for 3 items for my 65' Midget
chad
Hello,
My name is Chad Ward, and I am looking for 3 items for my MG Midget MKII.
The first is a "rear bearing hub for wire wheel". The hub that the bearing seats into, i need to replace one of mine. Moss Motors has it listed as part # 265-215 Bearing Hub, but is N/A right now.
The second item is the cockpit chrome trim pieces that sit above where the door latches are mounted on the body. Its not the chrome caps, but the 6 or 7 inch curved trim pieces that have the turnbuckles on them, i need both left and right pieces.
The third item i need, are the clips that have a threaded bolt on them that hold the dash pad and door top pads on. I could use about 10-15 of them. Thanks for any help finding any of these items, chad
If nothing more those clips for the pads are easy to make- a 10-32 x 1/2" long button head screw brazed or welded to a small square of steel and then grind the head down some. If you braze stainless steel screws on they will stay good for a long time!
Bill
Putting flats on a #10 flat washer would be an easy way to make the steel backs
Chad,
You have a PM
Dug
