Longbridge BN4 top frame question
blueskies
Assembly of the BN4 is coming along well, with a list of odds and ends left to do. Installing a new folding top is on that list.
I have a Longbridge top frame that appears more or less complete, except that it is missing the L shaped piece that is attached to one of the main top bows and extends below the left side pivot point and fits into the rubber block when the top is erected. I have the rubber block and the metal piece that the rubber block fits into. But the piece that fits into it is missing. I hope that explanation is clear enough; Longbridge owners likely will know what I'm talking about.
Does anyone out there have a Longbridge top with the missing piece still intact? If so, a few pictures - ideally with measurements of the piece would help immensely. Knowing the correct dimensions should make it possible to fabricate and weld the missing piece into place.
healey106
I think I might have a complete top frame in the basement storage area? would you be interested in using that?:driving:
B
blueskies
Thanks, healey106. But mine seems in good condition as far as rust free and straight condition goes. If I find other issues, I may want to talk to you about buying yours. As far as I know, mine is just missing the little dog leg extension at the drivers side pivot point. Close up pictures and/or measurements would save guesswork in remedying this.
B
blueskies
I found this image on line, of the "frame hook." In addition to needing dimensions, can someone tell me how this fastens to the top frame? Is it welded in place to the frame piece? I thought it was, but after seeing this image, I'm not so sure.
John Turney
It is welded. I would take and post a photo of mine for you, but I installed the top, folded it up behind the seat and attached my hardtop. It has remained there ever since. It's easier to remove and install the hardtop than it is to put the Longbridge top up & down.
healeyblue
Very true statement. I would have chimed in too but I am in the same position as John.
B
blueskies
Since I was not able to obtain measurements for the missing J hook, I went ahead with a "best guess" method. Getting the multiple angles right proved the most difficult part of the process. The result works well and clips into the rubber block mounted on the driver's side below the slide channel as it should. It also took guesswork to install the rubber block, since that part of the structure consisted of new metal without the factory holes. I did have an old rusty cut out piece to get clues on. So, all I can say is that the dimensions of the J hook likely are close to the original piece. It is also becoming obvious why Healey designers switched to the simpler top design when production moved to Abingdon in late '57.
Also, while the rest of the top frame was rust free and solid, test fitting it in the car revealed various issues. The various joints had seized from decades of storage and required lubrication and encouragement. Judicious bending and reshaping, using oxy-acetylene heat, also was required to have the two sides mirror each other and to form the desired profile. After sanding and painting, it will be on to installing the web straps and the new top.
Posting pictures of the parts prior to final cleaning and painting, with dimensions; maybe this will help someone in the future.
John Turney Longbridge BN4 Soft Top Austin Healey 9
longbridgehealey top frame for 100-6 BN4 Longbridge built Austin Healey 6
B Side window question for early Longbridge BN4 Austin Healey 4
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
Csarneson BN4 Longbridge Oversized Valves? Austin Healey 5
S BN4 Longbridge Question Austin Healey 6
5 Longbridge BN4 exhaust Austin Healey 9
C BN4 Longbridge interior Austin Healey 86
B 1957 BN4 Longbridge Austin Healey 2
H Early Longbridge BN4 Tool Bag Austin Healey 3
Barryp BN4 Longbridge / Abingdon feature combination??? Austin Healey 7
richberman Longbridge BN4 hood slide assembly? Austin Healey 0
John Turney Longbridge BN4 Sidescreens Austin Healey 6
N longbridge bn4 100/6 tonneau bar brackets Austin Healey 4
longbridgehealey 100-6 BN4 longbridge mirror Austin Healey 4
M Longbridge BN4 interior inner wheelwells Austin Healey 2
H BN4 2-Port Head Longbridge Registry Austin Healey 26
Randy Forbes Question about BN4 Longbridge vs Abingdon... Austin Healey 3
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
Csarneson Obscure Longbridge Parts Austin Healey 11
B Before and After Pics Longbridge 100-6 Austin Healey 5
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
R Longbridge Austin Healey Austin Healey 3
C Longbridge engine color Austin Healey 16
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
healeyblue The longbridge gets a hard top Austin Healey 17
T 100-6 Longbridge value Austin Healey 5
H Going to Hershey this week and anyone need anything for a Longbridge? Austin Healey 1
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
5 Longbridge sidescreen vs hardtop Austin Healey 16
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
5 Longbridge washer bottle Austin Healey 61
richberman Anyone rebuild Longbridge washer pump Austin Healey 4
richberman Anyone have Longbridge side screen frames? Austin Healey 2
5 Longbridge screen washer button dimensions Austin Healey 8
coj Longbridge Sliding Top Austin Healey 13
Randy Forbes Longbridge Engine Number / Clarke Spares Owner Passed Away Austin Healey 5
richberman List of bolts for 100/6 Longbridge Austin Healey 2
