London Black Cab
paul9999
Hello all,
looking for fellow black cab owners!
last year I bought a 1965 Austin FX4 - it runs, turns and stops, so no complaints there, but would like to trade ideas, help and horror stories with other owners!
Thanks
Paul (1965 Austin FX4, 1961 Austin mini cabrio)
PAUL161
Where's the pictures? PJ
JPSmit
Welcome Paul! yes, pictures indeed. I suspect you might be the only Cab owner on this forum - but, please don't leave! we need variety around here
paul9999
paul9999
took me this long to get photos!! ha ha
attachment.php
attachment.php
regards
paul
Jerry
We had two of the older cabs in our club, but the owner sold them. Get this! they went back to England.
Nice looking car and very different for our forum.
Jerry
That's very cool! But what are all those foreign cars in the second picture? Those are Cadillacs, which are French, right? ;)
PAUL161
Only looking at the exterior, it looks like a very nice example. Is it a diesel or gas? I wouldn't change a thing on it, leave it as original, it will carry a higher dollar value if you do. No radios or odd ball trinkets should be put in it and even keep the original upholstery if possible. It's hard for some folks to remember that they were a working machine, not a personal driver. They don't look right in any other format. JMHO. PJ
paul9999
paul9999
Planning on keeping it is original as possible. It is a diesel, so a little hard to start in the cooler weather, but once it's going it ticks (or is that "rattles") along forever.
We took it on the Woodward Dreamcruise a couple of weekends ago and it got a ton of interest, even though we were surrounded by muscle cars, supercars and wierd and wonderful examples of engineering.
paul
paul9999
paul9999
OK guys, an electrical question for you.
In the cab I have two batteries - and if I fully charge them, within a few days there is not enough power to start the engine (diesel). It may turn over a couple of time, then just "click click nothing"
I have charged both in the cab, then disconnected both and after a day or two measure about 12.7V on one and 11.2 on the other.
Can one battery be killing the other?
thanks
Paul
NutmegCT
Hi Paul - anything's possible if you don't know the car's history (and "improvements")!
How are the batteries wired? I'd assume that you have two batteries for a reason, if two are original to the car. One maybe for starting, second for operating (radio, lights, etc.). What voltage are the two batteries? Note: many older diesel engines needed two batteries to provide the amps needed to turn over that high compression engine.
Certainly possible that the batteries are way too old and don't hold a charge. Plus, I always use a battery quick disconnect, to prevent voltage drain. Example:
Do you have a wiring diagram and/or service manual for the car?
Tom
PS - I've got a copy of the owner's manual for the 1969 version. Glad to email it to you. Also, you might find this site helpful - London Vintage Taxi:
https://www.lvta.co.uk/archive.htm
and
https://www.ebay.com/itm/AUSTIN-FX4...IES-/310686870336?hash=item4856616b40&vxp=mtr
thanks
Paul
paul9999
paul9999
Tom,
I think it came with dual batteries - I assumed wired in series, but will check this evening to see if one does starting and the other, everything else.
I did consider a disconnect, but both have been so this week and one battery is definitely dying.
would be interested in seeing you owner's manual. I do have one on order but not due for a little while
thanks
Paul
John Turney
Nice cab! I stumbled on this thread just out of curiosity.
The battery that is at 11.2 volts is dead. 12.7V is fully charged. Assuming the two are supposed to work together, the 11.2V is draining the other.
paul9999
paul9999
John,
thanks for the info - I did get the lower voltage one checked, and yes, it is dead.
bought a new one and problem solved!
One seems to drive the starter only and the other everything else.
regards
Paul
paul9999
paul9999
Question for the group.....
I am tracking the multitude of electrical issues this cab has (and it looks like somebody has had a go in the past and given up!)
I have found a blown fuse but have no idea what rating fuse goes where - there are two fuse boxes, each with (i think) four circuits. There are no markings I can find and the existing fuses are an eclectic mix of ratings and variations on the "glass tube" type.
Any ideas? Can I calculate the best rating for that circuit?
thanks in advance
Paul
Cabbie
Hi Paul, My husband I just bought a 1967, Austin FX4 Diesel cab. I found a workshop manual on Ebay called Taxi & Hire car Series FL2, FL2D, FX4 and FX4D. I did not catch what your exact model number is, however, this manual has electrical diagrams in it. I have some electrical work that needs to be done on our cab, so I have a feeling it will get used quite a bit.
My cab also has two batteries and I have noticed while playing with my dash that you have to be sure that you have the main energy toggle switch off every time you leave your cab. If you do not, the battery will continue to charge whatever option that might have been left on. I am sure you already know this, so I hope you have been able to sort your battery issue by now. As I see this post is from 2015. Kristine
paul9999
paul9999
Hi Kritine,
mine is a 65 Austin FX4 so probably identical to yours.
there is a main energy toggle switch?? I never knew that.
Which one is it? I have several switches unmarked
thanks in advanced
Paul
eyearedan
I just got a 1976 FX4. it seems like it would be easy to get info on this, but dang, everytime I try to find a Youtube or other info, its just not there.
PAUL161
Some diesel vehicles with duel batteries were set up for 24 volt starting and 12 volt for the rest of the vehicle, I don't know a thing about the British cabs electrical system, just throwing that out there for a possibility. A battery with a shorted plate in a series duel battery system can pull the other battery down. PJ
M 1978 London Taxi Passengers Other British Cars 1
M London Taxi - What in the H**L do I have? Other British Cars 9
Num General TR London car show/cars & coffee? Triumph 1
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
L For Sale 1964 Austin FX4 London Taxi Other British Classifieds 1
tr6nitjulius Bentley Mclaren London Taxi @CCBCC All British 7/14/19 Other British Cars 0
H 1967[?] Austin FX4 London Taxi Other British Cars 3
E New London Taxi Owner 1976 FX4 Other British Cars 1
J London Austin Healey 12
jsfbond London to Brattleboro Austin Healey 0
Superwrench Visiting London Austin Healey 16
aeronca65t London Cab--China Other British Cars 1
Scott_Hower Post-War Other Met a nice Herald owner in London yesterday. Triumph 1
Luke_Healey Help IDing a car in London Other British Cars 5
B Days in London Healey Museum? Austin Healey 5
T Car stuff to do in London this weekend? Triumph 16
L London Taxi showing ourselves. Other British Cars 25
A Austin FX4 London taxi Other British Cars 9
fx4 London Taxis Other British Cars 8
T Hiram the London taxi Other British Cars 3
C Trip to London Austin Healey 9
S London Tips Austin Healey 5
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
KiwiStagguy For Sale Stag Black Mohair New top Cheap Triumph Classifieds 0
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
L For Sale 1964 Austin FX4 Black Cab Other British Classifieds 0
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
HealeyRick Just in Time for Black Friday Austin Healey 0
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
steveg Conclave Deadwood 2019 - Black Hills Maps Austin Healey 2
D TR6 1976 TR6 Black Painted Parts Triumph 2
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
JPSmit DeWalt or Black and Decker or DeWalt or ???? Restoration & Tools 4
mrv8q TR2/3/3A Califiornia Black Plate Syncronicity Triumph 1
Rhodyspit75 TR2/3/3A Speed is the new black. TR3 Triumph 5
AngliaGT Black Lightning Motorcycle Cafe British Motorbikes 2
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
AH67 General TR Touch up Paint 11/PAA Black Triumph 2
Zitch For Sale FS- Brand new Black TR4 Deluxe Carpet Kit Triumph Classifieds 2
Jim_Gruber New Tiew Rod Ends. Paint Black Y/N Spridgets 5
Jim_Gruber Paint Color - Black Satin or Black Glossy for Suspension components Spridgets 9
Csarneson BP Northwest Black Friday Sale Austin Healey 0
Jim_Gruber BE Gauges and Speedhut - Is it a 3 3/8" Gauge???? now 20% off Black Friday Sale Spridgets 10
