If I put SU's on a 4A in place of the Strombergs what linkage issues would I run into?Would I be able to use most of the linkage from a TR3 but require some from the TR4?
You'll need to source the 4A SU linkage too and keep in mind the the SU's on a TR3 are H6 and the 4A HS6. Never known anyone who installed H6's on a 4A, that may involve just using the entire linkage set up for a TR3. The HS6 TR4A set up tends to be a better choice simply from a potential gas leakage / sealing perspective.
That's right and I forgot to mention it. The HS6 is a shorter body than the H6. The 4A has a longer intake manifold to go with the shorter body of the Carb. Using an HS6 on a TR3 3A intake manifold would reduce the over all length of the intake manifold resulting in some performance loss. How much would be a guess.
The HS6 carbs also turn the opposite direction from the H6. The TR3 linkage (for H6) mounts to a tab on the intake manifold that may be missing or untapped on the later cars.
The H6 carbs would also be a step backwards IMO from either the ZS or HS6.
