TR4/4A Linkage?Swapping SU's on to a 4A
karls59tr
If I put SU's on a 4A in place of the Strombergs what linkage issues would I run into?Would I be able to use most of the linkage from a TR3 but require some from the TR4?
JerryVV
You'll need to source the 4A SU linkage too and keep in mind the the SU's on a TR3 are H6 and the 4A HS6. Never known anyone who installed H6's on a 4A, that may involve just using the entire linkage set up for a TR3. The HS6 TR4A set up tends to be a better choice simply from a potential gas leakage / sealing perspective.
Geo Hahn
If you look at the length (or is it depth?) of the respective intake manifolds you'll see where the 'S' comes into play.
Any particular reason why for this swap? I like SUs, but I like Strombergs too.
JerryVV
That's right and I forgot to mention it. The HS6 is a shorter body than the H6. The 4A has a longer intake manifold to go with the shorter body of the Carb. Using an HS6 on a TR3 3A intake manifold would reduce the over all length of the intake manifold resulting in some performance loss. How much would be a guess.
TR3driver
Great Pumpkin - R.I.P
The HS6 carbs also turn the opposite direction from the H6. The TR3 linkage (for H6) mounts to a tab on the intake manifold that may be missing or untapped on the later cars.
The H6 carbs would also be a step backwards IMO from either the ZS or HS6.
Todd78d Bugeye choke linkage Spridgets 5
Todd78d Choke Linkage Photo Austin Healey 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Sopwith_Camel linkage jag mk2 Jaguar 1
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
Michael Oritt Clutch Linkage Austin Healey 19
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
M Choke Linkage Austin Healey 3
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
AngliaGT MGB-GT SU Carburator Linkage - MG 9
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
Sarastro TR4/4A Stromberg linkage question Triumph 4
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
K TR2/3/3A Sloppy SU linkage and DIY bellcrank repair? Triumph 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
MY66AH Throttle Linkage Spridgets 9
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
F Gas pedal linkage BJ8 Austin Healey 6
S TR4/4A choke linkage Triumph 2
mgedit TR2/3/3A Link Rod Lengths Accelerator Linkage Triumph 2
GTP1960 TR2/3/3A Rear shock linkage orientation? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
GTP1960 TR2/3/3A Removing the silentbloc rubber pieces. From the steering linkage bush Triumph 7
J TR2/3/3A accelerator linkage for Weber 45 DCOE Triumph 4
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
T TR6 TR6 - alternative linkage design? Triumph 4
sundown TR6 carb linkage Triumph 7
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
T sourcing linkage ball/sockets Austin Healey 13
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
F BN1/BN2 Clutch linkage Austin Healey 4
K TR4/4A TR4A SU's replacing Strombergs....Linkage issues? Triumph 10
