Lilly under her own power...
  • Thread starter Deleted member 21878
  • Start date
went for a short test ride today. car ran and drove well. i am still fiddling with the throttle linkage. the pedal seems to want to hang up just before idle and i have to put my foot under it and lift up. i am going to try a couple of things tomorrow for that.
The drive went well with no shakes. ran up to about 50mph. did not have enough room to try the OD. May need to wait until i actually have the car tagged so i can get to some open road. steering felt fine and was not as hard as the TR6.
i also need to set the toe-in before the next test drive. when i put the front end together i screwed the cross bar all the way in so i know it is toed in right now.
but the engine felt good and the steering did as well. couple of pics from after the ride.
unfortunately even though the tires probably only have about 500 miles on them, they are 19 years old. So i don't want to run too far until i get some new tires.
Editor_Reid
Platinum
Congratulations! Looks like it was a very nice day, too.
I once owned a BJ8 in BRG/OEW (I know your Healey is not a BJ8). It was about the only one around at the time in that combo (mid-1980s), but the combo has caught on, to a limited degree, I suppose because OEW is about the only color you can use to two-tone a BRG Healey, and Healeys cry out for "duo-toning." (I've seen a couple with black as the lower color and it doesn't "work for me.")
CaptRandy
Drone, You sure completed that car in quick fashion. Seems like you worked around the clock. Congrats on job well done.
Thanks... well not finished yet actually. but the list is a lot shorter than it was. in fact, I hope to get it tagged this month.
after i took the pictures i told my wife i was done. her reply? Hahahahahahahahahah......hahahahahahaha.....hahahahahaha... (3 minutes later)...HAHAHAHAHAHAHA
guess she knows more about British cars than i realized.
gonzo
Well done Drone Dog...at least for now! Do you have a special rig for toe in? There are several techniques, but all seem to evade me. GONZO
Well something i made up. basically a flat "U" shape. the ends are 5" wide boards squared to the bottom rail. i used a system when i did the TD and have stuck with it. Seems to work fine. i set a 1/8" toe-in. seems to me i read that was recommended for radial tires somewhere.
AND, i just got my tires/tubes in today. So i hope to get the car tagged Friday and then over the weekend i want to get the new tires mounted and balanced. And then i am free to roam....
D Lilly is a now a cool car... Austin Healey 17
D Lilly test runs Austin Healey 4
D Lilly's graduation day Austin Healey 8
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
D Lilly Engine Latest Austin Healey 14
D Lilly Engine Latest / couple of questions Austin Healey 34
D Latest on Lilly Austin Healey 3
D Lilly Latest Austin Healey 1
D Lilly: Day one Austin Healey 18
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
J TR2/3/3A Pads under new floor Triumph 7
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
B Under bonnet fuel Austin Healey 15
D MGB Stopping rust under patch panels MG 1
T Coroplast Signs under Wheels Austin Healey 0
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
C Under boot and under bonnet paint? Austin Healey 7
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D TR2/3/3A Under hood Photos Triumph 7
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
G TR4/4A Under Dash Pics Triumph 2
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
K TR3A Air vent under grille on Race Cars? Racing 5
D TR4/4A shims under axle housing Triumph 7
simon1966 BN1 Strip down well under way Austin Healey 5
M TR2/3/3A The Sequel: Water from Under the Dash Triumph 3
Simmo MGA Missing under load MG 3
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
Joe Reed MGB Rattle under front end? MG 8
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
