TR2/3/3A Led flasher relay?
Lukens
I'm sure this has been discussed, and I know "search is my friend", but I'll ask anyway:
I replaced my TR3's turn and stop lights with LED's. I installed ballast resistors to compensate for the reduced amp draw. For more than one reason, I'd like to ditch the resistors.
Can someone tell me what "LED flasher relay I need? I'm running negative ground.
TIA
Russ
To work with a TR3 harness, you need a "3 terminal" flasher.
Sorry, I don't know which one is best. But unlike the later TRs, that third terminal is what drives the dash light on a TR3.
You could rewire the dash light to work with a 2 terminal, but you would need two more wires not in the original harness and a couple of diodes.
Understood. After a misfires, I spoke with a tech at https://www.memotronics.com/ He was most helpful and called out #EF33RL. That being said, I haven't received it. When I do I'll post results for future member searches.
