Ok, sways...lets have a discussion as to dia. I tried running a 3/4's and took out the frame mount on the right side I guess hitting a chuck hole...
I'm running 3/4's on 3 spridget's but had to re-enforce the frame horn's to do it. If you go over stock you can expect the mount to break but I would say 3/4 is about right for a street spridget. I torched out a hole for the stock mount in 3/16 inch stock and welded it in extending the load area over about 10 inches I believe. I also made up some mounts out of moly filled nylon rather than pay the big money for the after market aluminum one's.
Kurt.
