Adam58
Okay, my YB is leaking transmission oil at an alarming rate - even for an LBC! It appears to be coming from the drain plug but I suspect it can fool me by leaking higher and following down. It's a TD transmission. My questions are:
1. Do they ever leak from the drainplug?
2. Is the rear sear the most likley (and if not, what is?)
3. Can the rear seal be done in the car? Any tricks?
4. What is the exact size of the fill and drain plugs across flats? They are soft brass and I don't want to [mess] them up.
5. What should I refill it with in So. Cal? 80W/90 hypoid?
I'll jack it up and really check it out when I get in the mood but I'd like to know exactly what I'm looking for when I do.
Thanks! Adam
Thanks! Adam
