I had my m/c sleeved, also I needed the have the fitting ports helicoiled due to bad threads.
Now I'm having problems bleeding the hyd. sys.
I'm sucking air around the threads plus a slight hyd. leak.
Does anyone know if there is any type of sealant that is compatible with Castrol brake brake fluid?
Thanks
Thanks
