General MG Leaking Fuel on twin HS4's 1500 MG Midget
George P
Hi, hope someone can help me here.
I have a 1979 MG Midget 1500cc
Recently had my twin SU HS4's overhauled and since then I find I'm leaking fuel from the overflow point on the front float bowl.
I replaced the float bowl top complete with float and needle valve. Still I get fuel spilling out.
I shimmed up the needle holder by 1/8" in the hope that would help, nope still leaking fuel.
Float bowl was cleaned and I ensured there was no dirt. I fitted a nice new fuel filter in the line, still I get leaking fuel.
Only clue I have is that I fitted a new alu rocker cover with a screw in the cap, is this correct?
What else can I do ??
Thanks
maynard
IIRC, you can bend the hinge. I would also check the needle valve to be sure it is seating when the float is up. On second thought, I would do that first. You can try switching the bowl covers (front to rear) and see if the leak follows.
Mickey Richaud
G Twin HS4 Su's leaking fuel Spridgets 18
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
D Fuel leaking from carbon canister Triumph 6
D Leaking fuel pump connections Triumph 32
D Leaking fuel pump Spridgets 7
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
T Fuel sediment bowl leaking madness Triumph 12
A Stromberg Leaking Fuel Triumph 9
B Flex Fuel Line Leaking Austin Healey 7
Q SU Carb Leaking fuel at top Spridgets 8
N Fuel Pump Leaking MG 32
floyd leaking fuel pump Triumph 6
ronzet Fuel pumps, generators, and leaking SUs MG 10
drooartz Leaking fuel pump Spridgets 36
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
