paulsherman
First, SA comments about that happening with age. We all know that.
When I attached my float bowl , to the bottom of the carb. using "Hold Up Bolt" a flat washer, then a float bowl rubber grommet on each side, the "Hold Up Bolt" seems to be bottoming out. Can't make it stop leaking and it is tight. New rubber grommets.Any suggestions. Would adding another flat washer cause any problem with the fuel flow?
Thank you
Thank you
Hi Guest!
seriously, hope it works
