Judging by the results of a "piston lift" test both H6 carbs seemed a bit lean so I dropped the jets by about two flats of the adjusting nut and the mixture is now better. However I now have about a two-second fuel leak on both carbs, seemingly coming from above the nut and I am guessing that my dropping the jet allowed a worn or dried out gland/seal to crack and leak fuel.
It's been many years since my carbs have been gone through and though I see that Moss sells a couple of different rebuild kits is this more art than science--should I try to do it myself or am I best off sending the carbs off to Joe Curto or the like for a professional rebuild?
