Bradsudkamp
I have been working on my Healey for 33 years and never had a problem like this.
I drained the oil sump and refilled it. Had problem removing the spin-on filter, so i removed the adapter and the filter. Noticed some blue Permatex residue on the adapter portion that was removed, and I cleaned it off and attached the new filter. A small amount or residue was on the edge of the adapter portion attached to the block, and I removed it.
The regular gasket material was still in place so I reattached the adapter, stared the engine, and had no oil pressure. Prior to this oil change it carried 40 lbs at idle and 55 lbs when cruising.
I removed the filter and changed it. Ran engine and new filter was full of oil, so I reattached it. Pulled rocker cover and had no oil coming from the rocker shaft. Removed oil pipe from the rocker arm and had a small string of blue gasket material in the pipe, which I cleaned out. Removed the pipe and cleaned. Started the engine and no oil from oil gang. Removed the oil feed to distributor and no oil when engine started. Have removed the oil gang plug behind the distributor, but had to quit before I could start the engine.
I am cringing thinking I may have blocked the oil gang.
Anyone have any encouraging words and an easy solution to my problem?
