Lack of Oil Pressure
Bradsudkamp
I have been working on my Healey for 33 years and never had a problem like this.
I drained the oil sump and refilled it. Had problem removing the spin-on filter, so i removed the adapter and the filter. Noticed some blue Permatex residue on the adapter portion that was removed, and I cleaned it off and attached the new filter. A small amount or residue was on the edge of the adapter portion attached to the block, and I removed it.
The regular gasket material was still in place so I reattached the adapter, stared the engine, and had no oil pressure. Prior to this oil change it carried 40 lbs at idle and 55 lbs when cruising.
I removed the filter and changed it. Ran engine and new filter was full of oil, so I reattached it. Pulled rocker cover and had no oil coming from the rocker shaft. Removed oil pipe from the rocker arm and had a small string of blue gasket material in the pipe, which I cleaned out. Removed the pipe and cleaned. Started the engine and no oil from oil gang. Removed the oil feed to distributor and no oil when engine started. Have removed the oil gang plug behind the distributor, but had to quit before I could start the engine.
I am cringing thinking I may have blocked the oil gang.
Anyone have any encouraging words and an easy solution to my problem?
While I do not have a suggestion for the lack of pressure, you should not need to start the engine to check for pressure. Merely turning the starter will activate the pump enough to register pressure.
Bob
Thinking more about this. There is a maxim that the problem is always the last thing you did. Makes me suggest that you replace the new filter with another new filter. I assume the adapter of which you speak is for a spin on filter. Is it possible that you left some of the wrapper in place on the new filter, which is blocking passage of the oil?
Bob
It is possible that the oil pump has lost its prime. Some people drop the sump and pack it with vaseline or other lubes which would be "absorbed" into the lube oil.
The one time this happened to me I disconnected the coupling between the pipe that comes from the right rear of the engine and connects to the oil flex line running to the oil pressure gauge, then using a small oil gun I squirted perhaps 6-8 ounces of engine oil into the pipe and so back-fed the oil pump to prime it.
After reconnecting the line to the pipe and filling the engine with oil I started it and--VOILA--oil pressure!
Dollars to donuts you put the adaptor plate on upside down .
HN--
Just in case you are wrong--my favorite donut is a French cruller but seeing as how they're coming from Ottawa I'll take maple.
Brad--
If and when you resolve your issue please let us know what was the cause and what was the fix.
Though it is not required, "netiquette" suggests that when one poses a problem or issue they also post the solution. We all learn friom each other's mistakes, experience and knowledge.
