GT6 Label locations
Hoodat
Hello all,
My '70 GT6+ was repainted ~25 years ago. The painter removed 3 labels, but did not replace them. I do not recall exactly where these labels were. I'd like to put them back in their original locations. At least 2 were on the underside of the bonnet on the driver's side near the upper (back) edge. Can anyone tell me where these labels should go (maybe a picture)?
The labels: One is a metal plate 105 mm x 69 mm "Tyre sizes & Pressure..." and "Capacities"
Two are plastic labels. One is 120 mm x 63 mm "U.S. FEDERAL STANDARDS. CONTROL OF AIR POLLUTION." This one has marks across it where the full width seal just below the windshield marred it.
The other is 116 mm x 54 mm "TRIUMPH G.T.6. THIS VEHICLE HAS TRIUMPH EMISSION CONTROL..."
Also, on the left side under the bonnet below the shelf where the brake and clutch masters sit, near the bonnet latch, something may have been riveted on just above a riveted on metal strip (painted over) that has apparently the model series # "75004 KD" which is not the serial number. What could have been riveted there? It was not the metal tag described above; it was glued on somewhere.
Any help will be greatly appreciated.
Hoodat
UltimateQuestion
That riveted on tag is the body number, not the same as the commission number which should be on another larger embossed plate right above it. Sorry I have no idea about the under bonnet decals or tags, mine has none.
H
Hoodat
Thanks, Tony. You gave me a place to start by identifying that the commission number tag should be where I asked. I found a photo on triumphspitfire.com that shows the tag. The commission tag was ultimately moved to the left door pillar, just below the latch, where mine is. Thus, my GT6 never had a tag under the bonnet, just a couple of rivets plugging the holes.
Guess I panicked when I couldn't find the tag there... ;)
Hoodat
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
B TR4/4A I mangled the patent label on underside of hood - Triumph 9
I TR6 Emission Control label for 69 TR6 Triumph 1
A Blue label OD does not disengage MG 8
Jim_Gruber Wheel Bearings and Thrust Label Spridgets 6
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
jfarris TR2/3/3A Small Manifold Clamp Locations? Triumph 5
T TR2/3/3A TR3 Gearbox Top Cover OD Switch Locations Triumph 6
C TR2/3/3A Speedometer cable fastener locations Triumph 14
G Snap locations for BJ8 tonneau Austin Healey 10
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
B Slot locations for Sprite front emblem Spridgets 2
Patrick67BJ8 Stud Locations - Cylinder Head & Exhaust Manifolds Austin Healey 3
Boink Fuel filters... locations, types... Spridgets 8
Got_All_4 Wedge TR7 PI Relay ECU etc locations Triumph 23
Cottontop Locations of Future Conclaves & Rendezvous? Austin Healey 3
Patrick67BJ8 Red Grommet Locations for a BJ8 Firewwall Austin Healey 4
J Need tenex and LTD fasterer locations for BJ8 Austin Healey 0
G Mounting hole locations Triumph 0
davidk Jack and lug wrench locations Triumph 8
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
SCguy TR4/4A TR4 Voltage stablizer/flasher locations? Triumph 5
B BJ7 Seat Mounting Hole Locations Austin Healey 5
G Mapping locations of Triumphs nationwide Triumph 105
N VIN number locations Triumph 2
