Kent AH4 cam shaft
Walter74
Good afternoon,
I am able to source a Kent AH4 cam shaft to upgrade my BJ7 engine, but I am not able to determine whether or not valve pockets in the pistons are necessary for this cam shaft.
Does anybody know this?
Thanks in advance for your advice!
John Turney
Do you know the lift for that cam? That will determine if you need pockets. Are you using the stock rocker arms? If you change the arms to a different ratio, you may need pockets.
dcarlg
Walter74,
Welcome to the forum.
Sorry, but I don't know if the block needs to be pocketed.
I found the specs on the web site for Kent Cams.
11.57 mm valve lift.
This cam is for an MGC motor.
Good Luck.
Doug Glesmann
BBH
I have just put a Kent AH4 profiled cam into my rebuilt engine and I did include valve pockets for clearance.
John Turney
Yes, 11.57 mm definitely requires pockets. I have a Denis Welch DWR 8 cam with 10.18 mm lift and pockets are required. The Denis Welch DWR 1 cam at 9.09 mm lift does not.
BBH
Too early to tell as it is still in restoration. I have run the engine, but only to bed things in.
Engine builders use a type of clay--PlayDoh works, I hear--positioned on top of a piston. They rotate the engine through a compression stroke and measure the depth of the pocket left; if a valve hits the top of the piston I'm not sure what they do (maybe mill pockets until the valve clears?).
Betcha Dougie knows.
red57
Is it difficult to determine the positioning and depth of the pockets?
In the case of the Healey motor it's pretty straightforward because the valves are vertical and the only interference is with the exhaust valve over the deck (it would take a very radical situation to have piston to valve clearance issues - perhaps Dougie's motors are that radical?).
Locating the pocket is simply a matter of blueing the deck, setting the head on with a loose exhaust valve (no spring/retainer) and manually spinning the valve against the deck to make a mark in the blueing on the deck. Typically adding an 1/8" or so to the diameter of the mark for 'safety'.
Depth of pocket is determined by knowing the lift at the valve of the cam you want to use. Then measure the distance from the surface of the closed valve head to the head gasket surface + gasket thickness (stock type is typically .040) + whatever clearance your machinist suggests (typically around .040 for this situation). So, if the valve lift is .450 and your measurements add up to .400, then you need .050 deep pockets. You don't want the pockets any deeper than necessary because they enlarge the combustion chamber size therefore lowering the compression ratio.
And playdoh is a nice confirmation before running the motor.
Dave
John Turney
There’s no pocket in the pistons, there are pockets in the block. The intake valves go wider than the bore. The head gasket has pockets in it to avoid the valves. That will tell you the position of the pockets. You’ll need to assemble the head off the engine and apply 11.57 mm lift to the rocker arm and measure how much the valve extends past the face of the head. That will tell you how deep to go.
GregW
Platinum
Here is a visual for you on the pockets.
dougie
Radical yes, but no pockets needed in the piston, just a beautifully milled dome. With the combination of cam lift and roller rocker ratio, I'm at the max pocket depth.
Healey Nut
What are the black flare fittings for Dougie , an external oil cooler ? Also what are all the threaded plugs for by the freeze plugs .
dougie
Race motors never see freezing temperatures, but simple plugs can fail under extereme (6-24 hour) race conditions. The threaded plugs stay in place and the large freeze plugs are epoxied sealed. The black flare fittings are part a special designed and engineered side oiler system which inputs the oil from the oil cooler directly to the crank & main bearings first before circulating throughout the entire motor. This is the key to extending the life of the custom billet crank....
Healey Nut
That crank is a piece of art . Tks Dougie .
Walter74
Walter74
Wow, that is next level engine building. A bridge too far for my road car:smile:
I will stick with some simple pockets in my block. Thanks for all the useful information. I already found a good machineshop to help me out
Editor_Reid Memorial Information Added | Kent Lambert, RIP Austin Healey 10
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
HealeyRick RIP Kent Lacy Austin Healey 6
C Ford 1500 Kent pre-crossflow mystery Other British Cars 16
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
aeronca65t More Kent engine info Racing 3
swift6 Ford Kent Engine to resume production... Other British Cars 19
swift6 Ford Kent Engine to resume production... Racing 5
aeronca65t No more Kent in FF? Racing 1
Dudly Kent Ohio, British Car Show ? Triumph 4
K Kent Cam valve lash ? Triumph 2
GB1 Kent Cam Spridgets 11
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! Triumph 10
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! MG 11
G Cigarettes shop-$ 14.95 for Marlboro,Camel,Kent!!! Austin Healey 7
Basil Kent Cams Triumph 8
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
R TR6 Cam choices? Triumph 23
