K&N air filters for 1967 BJ8
gcoll
I'm sure this subject has been covered before but I am interested in replacing the original air filters with a K&N or equivilent modern air filter on my car. Can anyone tell me the K&N model number that is compatable with the SU HD8 carburator and where they can be purchased? What are the pro's and con's to upgrading the air filters, any thoughts or ideas concerning this conversion would be appreciated. thank you glenn
Keoke
See post on after market ones on this same forum. However, there are not any other type i would recomend using
BoyRacer
Keoke, I'm trying to find "post above on aftermarket ones" ...and I can't find it . Archives ?? I can't find it. I may be clueless, but I also want some info on a good air cleaner for my HD8s. So listers, please wade in and help us out. I Googled ITG, but they are made in England and I want something made in the US.
bec
Patrick67BJ8
bec
I've been looking for a long time for an aftermarket air filter for my BJ8 and the below link is the only one I've been able to find. Just so happens it appears to add performance and some good benefits when working on your carbs. I have contacted the company about a month ago and they are in stock and I will most likely buy one, about $160.00 USD. They do stock replacement filters too. Something about the BJ8's that companies don't want to come up with a system for them but do on the other big Healey's.
https://www.bighealey.co.uk/content/high-flow-twin-su-air-filter
peter41692
This is what I used. K&N
peter
Bustren
When I converted my BJ8 to 3xHD8 I bought three K&N 56-9242 blanks, was just enough room for these. For a standard BJ8 installation I would check if there are room for slightly higher filter.
I made three drawings in scale 1:1 (three offsets used) which I glued inside the end plate using the 2 holes for the studs as reference. Holding it against a light source makes it quite easy to position the drawings. Easy to mark and drill the holes, then use a hole cutter for the intake hole. Used a Q.Max sheet metal punch hole punch diameter 52 mm.
Make sure there are no interference between the screws for the studs inside filter and the carburetor (I changed these screws to insex). Using a gasket for the filter as reference makes it quite simple to check clearance.
For the ventilation breather hose I made a hole in the rear filter end plate, slightly smaller than the hose and just pressed the hose in. Make sure the hose do not interfere with filter element, it is little tight. brg Lars
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
Writer2022 GT6 Overheating after fitting air filters Triumph 4
tahoe healey Cooper Air Filters Austin Healey 7
S TR2/3/3A restore my original air filters Triumph 5
N Air filters Austin Healey 5
JFS TR2/3/3A Weber Air Filters Triumph 7
doc50 Wanted H2 Air filters for 73 Midget Spridgets Classified 0
PeterK TR4/4A DCOE air filters Triumph 5
B Welch air filters Austin Healey 5
F What to do with breather pipe as my new air filters have no connection for one? Austin Healey 31
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
PatGalvin TR2/3/3A TR3A After Market Air Filters? Triumph 31
Gearhead_Garage Big Healey Air Filters Austin Healey 22
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
Lin K&N Air Filters for SU HD6 carbs Austin Healey 14
D TR6 Air filters Triumph 2
S Best air cleaners/ filters for street Spridgets 8
fad64b TR2/3/3A TR3 Air Filters Triumph 7
A Anyone have air filters to sell? Triumph 5
A TR2/3/3A What air filters for '59 TR3? Triumph 17
H filters inside of BJ air cleaner? Austin Healey 24
I Stock bugeye air filters Spridgets 9
K SU Carb Mix...Air filters on? Triumph 4
E Painting stock air filters Austin Healey 7
8 TR4/4A Upgrade Air Filters for Stromberg TR4A Triumph 6
M TR2/3/3A Proper servicing of TR3 air filters Triumph 20
G Where can I find the chrome "MG" air filters? Spridgets 4
S Wedge TR8 non EFI, Air Filters Triumph 2
D K&N Air Filters MG 5
D Ported/Manifold vacuum and air filters MG 0
angelfj1 Unusual Air Filters Triumph 28
johnrip Wedge TR7 with K&N Air filters. Where to mount dipstick? Triumph 2
JohnnyMead TR2/3/3A Re-Oiling the TR3 Air Filters Triumph 0
J Removing Air Filters Austin Healey 15
KVH SU Carbs Paper Air Filters Triumph 4
humanoid replacement air filters for dual Webber carbs Triumph 19
K Best air filters? MG 7
B Air Filters for Triple Webers, BT7 Austin Healey 9
ArtQ Air filters Austin Healey 2
jjbunn New Air Filters for Harold MG 10
jjbunn Air Filters MG 32
Team_Sprite finish on 948 air-filters Spridgets 12
S TR2/3/3A tr3 air filters Triumph 3
G triple zs air filters - any ideas? Triumph 4
sparkydave Anybody use Longflo air filters? Spridgets 15
