Don Elliott
Use a fan belt that has cogs on it. Check Gates - mine I believe is a Gates 985. They are thinner in the vertical height and are more flexible. Therefore you can fit them on without any trouble and they flex around the pulleys. Mine has been on since I snapped the last one (a heavy original style) back in 1993 and I've driven 81,000 miles since then with this cogged belt. I was on the highway 300 miles from home when it broke and it took me less than 5 minutes at the side of the road to put on my spare belt, the new cogged one. The old rigid ones are a pain to put on - too rigid, too wide and too high to fit them around things you can't see down there and they are too stiff to flex around the pulleys. They want to stay straight and so they break after about 5,000 miles. It's time for me to make another change because I can't get any more adjustment on the pulley on the front of the generator. The belt seems to have stretched. But I really think the "V" side-walls have worn, so the belt is no longer a s wide as it was when new, therefore it's sitting deeper in the pulley grooves.
Don't tighten the belt too tightly, no matter which type you have. Tighter means it'll break sooner and the bearings in your water pump and generator will go on you. And your water pump will start to leak too. It needs to be just tight enough so that it doesn't slip with that squealing slipping sound when you accelerate.
