There are a lot of loose wires in this car.That cluster of dangling wires should be for the tach. It needs a couple slight mods to work accurately with a negative ground setup, not difficult. The white wire is the ignition from the switch to the coil, the tach works on induction pulse from that. The yellow wire is an "extra" circuit for an overdrive apparently not in your car, with the switch mounted in the opening to the left of the fuel gauge when fitted.
Is the rheostat the "P" knob between the tach and speedo?The dual OP/temp gauge is mechanical, an ether bulb (expanding gas) for temp and a copper pipette from engine to gauge for oil pressure. Only has an electrical connection for an illuminating bulb. All dash lights are (or should be) on red/white stripe wires. Solid red to rheostat for power, out from that to instruments.
Have a look at the wiring diagram. The white wire should have a small loop around a plastic holder which is held to the back of the tach with a small metal "horseshoe" clip. For an induction pulse, not direct connection. That plug is something someone used to cover the hole for a switch if overdrive was installed. Otherwise the hole had a metal plug fitted.There are a lot of loose wires in this car.
I need a little more help to make sure that I understand. I do not have overdrive, is the "plug" normal or is there something else that should be there?
are you saying the tach wire should be connected to the white wire?
Yep. "P" is for panel... the instrument lights.Is the rheostat the "P" knob between the tach and speedo?
What is the mechanical connection for the temp and pressure?
I found a purple/ black in the turning signal switch harness, but it runs into the "loom" and under the hood I would think. I cannot find the other end of the one in the steering column, or is it soldered into the column and the brush connects it to the car?
Strip all the Lucas wiring out.The 1966 MGB has been converted to a negative ground, with an alternator.
My first issue of concern:
The turning signals do not work. The head lights, tail lights and running lights in front illuminate, the switch on the steering column has been replaced, none of the interior lights work.
I removed the interior light bulbs, they tested OK. I would like to replace all of the lights with LED.
Please help me trouble shoot the turning signals.
Thanks,
John
Chicago
View attachment 91862View attachment 91863View attachment 91864View attachment 91865View attachment 91866View attachment 91867
where does the painless come from, Summit does not have oneStrip all the Lucas wiring out.
Buy a Painless wiring harness and install it.
Buy and install all electrical gauges from Speedhut.
Or you can go with an original harness from British Wiring.where does the painless come from, Summit does not have one
Painless Performance Products or, Rebel Wire.where does the painless come from, Summit does not have one
If you want a true British wiring harness, I've got a sparePainless Performance Products or, Rebel Wire.
Just order a generic or hotrod kit
I do not know anything about these, what is the time commitment to install? probably less than running down the problems.If you want a true British wiring harness, I've got a spare
You're correct. Forget the wiring harness. Just chase down and fix each problem created by the Dark Lord, Baron Verladimer von LucasI do not know anything about these, what is the time commitment to install? probably less than running down the problems.
