Hi Guest!
OK, Gerard can I expect about the same price as Nelson payed? Header just has a bit of surface rust mainly on the inside of the tubes. New, just sat around for a while. Are the claims I've heard accurate? IE:Cuts down on heat in the engine compartment and makes he header last??
I was thinking exhaust wrap tape till someone pointed out short header life. I would assume the tape would keep engine compartment temps lower than ceramic coat.
Kurt.
Hi Kurt, I had my headers done inside and out. That was near 10 years ago and they still look good. I have never had a heat problem even traveling long drives on interstate in 100+ temp days.
If you like white, take a look at Swain Tech: https://swaintech.com/race-coatings/race-coating-descriptions/white-lightning-exhaust-coatings/
