Hi folks,
Next job is replacing the soaked rear brake shoes and rear hub oil seal, etc.
One tip I heard about was to jack up the side of the car you are working on and that way when you pull out the half shaft all the oil stays in the other half of the axle case.
So, where to put the trolley jack and where to put the jack stand(s)?
I was thinking of the trolley jack under the rear jacking point( where that rubber plug is), under the flange, and then a jack stand under the leaf spring bracket.
Cheers,
Adrian
Cheers,
Adrian
