Jacking points for one side of Midget
bigjones
Bronze
Hi folks,
Next job is replacing the soaked rear brake shoes and rear hub oil seal, etc.
One tip I heard about was to jack up the side of the car you are working on and that way when you pull out the half shaft all the oil stays in the other half of the axle case.
So, where to put the trolley jack and where to put the jack stand(s)?
I was thinking of the trolley jack under the rear jacking point( where that rubber plug is), under the flange, and then a jack stand under the leaf spring bracket.
Cheers,
Adrian
I'd just jack under the pumpkin and put the jack stand under the axle.
bigjones
bigjones
Bronze
Trevor,
Thanks for the reply.
I think I tried it that way once but then I couldn't remove the wheel! Maybe on a round wheel arch it would work?
Cheers,
Adrian
Hmmm... I hadn't thought of the issue presented by a SWA.
JPSmit
You don't want the trolley jack under the jacking point - the pipe in the jacking point will take the weight - the floor will not - D DPO.
Jack it up on the pumpkin. Take the jackstands and put them under the lip of the body just ahead of the wheel well. Use a piece of 2X4 to protect the body. I actually did it two nights ago and ran a piece of wood the entire width of the car which reassures me somehow.
https://tinyurl.com/bnyyau
then you can angle it side to side.
bigjones
bigjones
Bronze
JP,
Thanks for the post. You saved the Midget from getting a big crumple. Thanks also for the clarification - the bit about the pipe can take the weight but not the body.
Come to think of it, I used your method when I swapped the leaf springs from side to side, because I could not use the rear spring brackets (my favorite jack stand position).
I don't think I'll try to angle it side to side. (I TRY to be very safety conscious). If any oil comes then so be it. Out of curiousity, how would you go about angling it?
Cheers,
Adrian
scoutll
Try going one notch lower on the offside jack stand. That should be solid and still let gravity work.
JPSmit
I think I'd either do what Bryan proposes - which won't (I hope) compromise safety. Or - on your work side put the jack stand under the lip of the body and on the low side under the front spring bracket.
another possibility as I sit here is to only jack up one side of the car - leave the other side on the ground, maybe with a 2X4 between the opposite wall and the farside tire (to keep it from sliding sideways) I'm so used to jacking up the entire car but here it might be worth keeping the car stable that way.
bigjones
bigjones
Bronze
Thanks for the tips.
On a final note, I tried to put the 2x4 across the car but the exhaust pipe got in the way. Didn't fancy sorting that out - I forget how I done it last time.
I just ended up supporting the car on the axle brackets like I normally do.
I took the half shaft out and the oil is just dripping out - no big deal.
Cheers,
Adrian
S Healey jacking points and jack stand placement Austin Healey 13
A Jacking Points '59 Bugeye Spridgets 5
D Jacking Points Jaguar 3
Y Jacking points and jack stand placement on Europa Lotus 1
martyc T-Series MG TD Jacking/Jack Stand Points? MG 4
Patton Jacking Points [ to Avoid Frame Damage ] Austin Healey 15
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
X BE jacking tube access holes and top bows. Spridgets 1
F Chocking the rear wheels and putting in gear when jacking up the front Austin Healey 8
W Jacking OOPS Jaguar 1
W Etype Ser. I front crossmember jacking Jaguar 3
GTP1960 TR2/3/3A Jacking up a TR3A Triumph 31
CJD TR2/3/3A Jacking Without a Wood Block Triumph 12
bugedd Jacking up the car Spridgets 29
B TR6 TR6 Engine leaks, jacking questions Triumph 9
M jacking point rocker debris Spridgets 3
B Race spridget weight jacking Racing 8
T Bugeye rear jacking point not including axle Spridgets 3
V TR2/3/3A Jacking up a TR-3B Triumph 4
R Jacking question MG 6
G Jacking Plate Triumph 2
Woodie jacking and axle stands Spridgets 4
drooartz Jacking and axle stands Spridgets 15
7 Jacking and Jack Stands Austin Healey 25
S MGB Jacking an MGB MG 21
A "jacking" up prices Austin Healey 27
SpannerMan TR4/4A TR4 floor jacking holes... fact or fiction? Triumph 11
G Jacking problems.... Triumph 3
A Jacking my midget? MG 17
J E Type Jacking point Jaguar 7
C TR6 Seatbelt anchor points Triumph 2
L T-Series Back to org. points MG 3
P TR2/3/3A NO spark at points Triumph 36
drooartz Bugeye jack points to remove rear axle Spridgets 18
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
W Seatbelt Anchor Points Austin Healey 2
T TR2/3/3A bad napa points Triumph 9
steveg Points assembly order of washers Austin Healey 13
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Disributor Points Triumph 3
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
T TR2/3/3A tr3 points& condenser#'s Triumph 6
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
