PeterK
All this talk about the rear seal conversion made me do it.
I've had my crank installed in the block for over a year now, waiting for the rest of the engine to be assembled. Just haven't had the spare time.
At the time I had the crank turned, I also had them turn off the scroll for my seal conversion from that I purchased from BPNW a few years back. It was one of those that stated 2.500" incorrectly on the instructions.
So since I couldn't remember the details, I went ahead and pulled off the front saddle, front plate, and then the crank came out. It was a royal pita to get the rear main cap free, finally used a heat gun to soften the loctite and silicone holding on the aluminum seal plates. I need to order new cork and felt block and probably a front plate gasket.
drum roll ... crank measures 2.508" which is probably ok once I cut the seal spring down from 8.5" to 8.0". I'd forgotten but the seal is hinged (not two pieces).
I lapped the aluminum sealing plates on a piece of emory paper on granite to get the edges tight. And I'll probably build a small layer of #3 around the sealing circumference to tighten it up as prescribed too.
Don't really know what else to do. The crank is beautiful and I can't scrap it and start over.
All these discussions really get me second guessing my work. It was probably going to be a leaker, but not a gusher as-is. But will be drier with the spring cut shorter.
I'm following these https://www.socaltriumphs.org/docs/mainseal.htm instructions on sealing. Anything else I need to do?
