jjbunn said:
I don't think the relay is needed for the J (but I have one if not)
Not needed. The J-type solenoid draws much less current than the A-type does (2 amps versus roughly 20 amps for pull-in), so no relay needed. Not that it would hurt if you want to use one, but it's not necessary.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Did you just wire the bulb in series with the lockout switch? That was how I was planning on doing it, and then mounting the bulb on the dash support console (I have a spare hole).[/QUOTE]Wiring the bulb in series will not work, as then the solenoid will not get a full 12v. Instead, connect it from the load side of the operating switch to ground. That offers another advantage as well, it will stay on even when the gearshift is in neutral or first (which IMO is mostly when you need to be reminded that the OD is switched on).
Geo Hahn said:
You may want to modify the gearbox tunnel to provide some access holes for common maintenance and adjustment (unless 6s come with those holes in place).
The J-type was redesigned to move ALL maintenance and adjustment points to the bottom. The only operation from the top is filling the gearbox with oil.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I found I could peel off that outer black covering and the shaft underneath was shiny metal. Not quite chrome but very bright.[/QUOTE]Check out
https://www.jmwagnersales.com/ltslssr.html for a cheap way to get very good looking chrome on one of these stems.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Randall had recommended a slo-blow fuse on the power to the solenoid to protect it should the pull-in coil fail to disengage. Seemed like a good idea so I added one. [/QUOTE]
That's only suitable for an A-type (or D-type). The J-type has no pull-in coil (which is why it draws much less current), so a fuse is not needed for that reason. And because of the lower current, you can just take power for the switch from the "green" (fused ignition) circuit, so no extra fuse is needed even to protect the wiring.
jjbunn said:
Could one use a bulb/light in place of the fuse? That would serve two purposes: some current protection and also a O/D engaged indicator?
Nope. Again, the bulb would not pass the current needed for the solenoid. Two devices in series must split the voltage applied to them (with the lower resistance device getting less voltage). With a fuse, the resistance is basically zero, so the series device gets full voltage. But a bulb is designed to take full battery voltage (and draw relatively little current).
