Don Elliott
Be careful not to cut the old wire too far back if you decide you need to clip off some bayonets. After you make the repair, you still want to have enough length (and looseness) so you can insert the bayonet into the connector otherwise the shortened wire may pull the bayonet back out the female conncetor.
That's why I try to leave all the wires at the original length - to avoid tension on the wires if they are cut too short - too many times.
I bought some new connectors and have torn the old rusty ones open to get the bayonet out. Then I would clean the bayonet exterior by Frank's methods or something else and you may not even need to un-solder and re-solder the old bayonet (or a new one) unless the stranded wire really looks like it's had its day and might break.
BTW, it's possible that the weak looking wire became that way when some PO used the corrosive acid core solder which may have eaten away some of the tiny strands. The use of acid-core solder may have also helped to corrode the bayonet into the connector which might resemble a rusted-in bayonet.
