The needle doesn’t move at all. Like, the gauge is dead. thank you for your advice, I will look into the tank first and check the float. Where’s the float connected to the gauge? I may as well check the wiring.First does it read any fuel. ?? and does it move at any point? most time the float goes bad with todays gas and sinks. Also any moisture can rust the pivot sticking it at a fixed point. The gauge works by reading ohm to ground and is rarely the problem. Getting acc. to tank and replacing float assy. is most likely the fix.
Alright, I will pass this to my friend. He's looking to get this BT7 project with the fuel gauge issue. The owner wasn't sure what his eldest son did to fix it as it is still not working. We'll take a closer look soon after we finished installing the brake kit and nitto tires on the pick-up truck this weekend.The mgaguru.com website has quite a bit of technical info. Here's a article on troubleshooting the fuel gauge/sending unit.
And very easy to replace. There is one YouTube out there that illustrates install. Search “fuel sender replacement on Austin Healey”. Also…very important to install a simple extra ground wire from one of the 6 screws on the fuel sender. I ran mine to the screw on the spare tire fastener. If I can fix this, anyone canThey all look something like this
