Initial set-up of carbs for first run-up
chicken
I am nearly ready to fire up my BJ7, i have been through the carbs and replaced the neccesary bits from a SU parts pack. When i intially start the egine do i have to be worried about any specific settings for the carbs, in other words if i set things up how i think now and run it will it damage the engine if i have made a mistake!!
Rob
steveg
There are several googleable documents on the web regarding tuning SUs that discuss initial setup and the "lift the pin" method of setting the carbs between too lean and too rich.
If the car runs OK and doesn't ping and isn't too rich, there should be no damage.
Keoke
Rob
Just make sure that the SU fuel pump runs initially and then shuts off, it is ok if it clicks ocasionally after that.Now set the choke full on and see if she fires up and as has been said runs OK.---Keoke
Keoke
anthony7777 said:
chicken, i would advise having a fire extinguisher handy.
7777's, Rob says it won't fire !.---Keoke--- /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
John Loftus
Rob,
One of the 'initial settings' is the number of turns on the jet adjusting nut. First you center the jet and bring the jet level to the bridge in the carb body. Then lower the jet by unscrewing the jet nut a full two turns (also read up to 2 1/2 turns). This will give a good approx. setting that can be tuned later for rich/lean conditions.
It's also a good idea to do a 'drop test' on the pistons/chambers during the rebuild to make sure you have an equal drop time. If you search for the Dave Russell post on the subject it will explain how to do the test.
Cheers,
John
chicken
chicken
John
Thanks i'll try that, have also found some other info on the net so will have a little tinker.
Only thing is i'm not likely to get it running yet as i'm having problems getting a spark !! (see other post)
Rob
i figure if the fuel pump is running and it has a "rare" su leak after a rebuild he may get lucky .... ya know the rest, i also think it wise not to attempt an initial start up with the car in the garage, thats just silly old me. /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
Keoke
<span style='font-size: 17pt'> </span>
Oh!!!!---------------------------Keoke
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
KVH General Tech Initial Start Up After Rebuild Triumph 23
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
G Failure on Initial Engine Start After Rebuild Austin Healey 176
S TR2/3/3A initial startup of a motor Triumph 20
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
drooartz Tunebug vs MGB, initial thoughts Spridgets 67
deadair Initial adjustments of SU H6 Carburetors Triumph 9
mjobrien Suggestions on initial timing for BN1 Austin Healey 3
R Initial startup after 22 years Austin Healey 22
mjobrien Initial Oil Pressure - Oil for break in? Austin Healey 20
J initial start seeting after engine overhaul Spridgets 2
B Ignition help - initial startup not going well Spridgets 5
jlaird Initial word is out Spridgets 22
ronzet Initial Carb setting.. twin SUs BN4 Austin Healey 7
Michael Oritt Initial/total advance settings Austin Healey 10
R Engine Rebuild--Initial Start-up Austin Healey 5
S TR2/3/3A old 4 bolt axle set up Triumph 12
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
S Weber carb set Other British Cars 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
Gatheringtree TR2/3/3A Gauge Set Triumph 17
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
J TR2/3/3A Confirming Cam Set Up Triumph 5
Walter74 Insulation set from Koolmat Austin Healey 3
G Valve adjustment and easiest way set cam position Austin Healey 15
Michael Oritt HD-6 support set Austin Healey 4
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
S TR2/3/3A understanding the float and needle set up better Triumph 6
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
R For Sale Italian Triple Weber Set Triumph Classifieds 1
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A paint gun set up Triumph 15
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
K TR2/3/3A Rear bumper over rider set up. Triumph 2
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
D BT7 tri-carb linkage set up Austin Healey 23
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
