Ignition warning light
M
Member 10617
Can anyone explain the function of the TR3 ignition warning light? Until yesterday, the light went out and stayed out whenever I started the car. Yesterday I had to have my regulator and generator replaced (one fried the other???). Now, the ignition warning light comes on when I am about to start the engine and goes off once I have started, but it comes back on whenever I am idling or am at 1000 rpm. There is a cryptic statement in the Triumph handbook about this, but not much and not very clear.
Mickey Richaud
Lex -
Sounds like the light is doing its thing: letting you know when the generator isn't charging properly. When the idle is up, generator is putting out enough to run the car and charge the battery.
1000 rpm sounds a bit high for it to be just going out. When you replaced the regulator and generator, was the battery checked out? May need a proper charge.
Hope this helps, and I'm sure someone else will chime in here shortly.
Mickey
tomgt6
Also check your belt tension. I could be the belt is a bit loose and slipping at slower speed. I also agree with Mickey.
M
Member 10617
Mickey, Tom, and Andy,
Thanks for the input. I was unsure why the light was coming on when the car was idling (and had not before yesterday's incident) but now I see that THIS is normal and whatever the heck was going on before was not normal. I learn something every day.
The mechanics (at a shop that specializes in Triumphs) checked the battery, cleaned the posts, etc., etc., so I think it is OK. They also set the belt and I have to assume it is tight enough. On my way home -- about 50 miles from the shop -- the ammeter rose to about 30 when I started, but at cruising speed it remained at between 0 and 30 most of the way home.
Here's what one of the mechanics subsequently e-mailed me. "When we tested it using a digital volt meter it was normal. On a generator system it takes some time for it to get to a higher charging voltage. It starts at battery voltage around 12.5V and goes up slowly to about 14V depending on load. When at idle it is not turning fast enough to charge (light on). Different voltage regulators will start charging at different RPM, usually just above idle. Yours kicks in a bit high but still normal. What wasn't normal [yesterday] was that when it went off it came back on at a higher RPM. Hopefully you won't see that again. Next time you are down this way we can check your idle speed with a digital tachometer. By ear I don't think your idle is as high as your tach reads."
Lex
TR3driver
Great Pumpkin - R.I.P
That is certainly a possibility. Those old mechanical tachs tend to read high as they wear. I haven't checked it, but mine reads around 800 at what feels more like 500.
And the speedo reads over 100 mph at around 70 actual, but that's a different story :laugh:
TR3driver
Strange, I know I wrote this up, but I don't see it in this thread.
When the key is on, the red light on the dash basically indicates the state of the "cutout" contacts inside the control box, which connect the generator output to the battery. When the generator output drops low enough (due to low rpm), the cutout is supposed to open as otherwise current would flow backwards from the battery into the generator (trying to turn the engine).
Normally, the light should stay out (contacts closed) down to idle rpm. But if your idle is a bit low (etc), it may come on without necessarily indicating a serious problem. As long as it goes back out (and stays that way) at higher rpm, it probably is not indicating a problem.
If you are interested in double-checking your garage's work (or just learning more about how the charging system works), there is a fairly simple test procedure in the "Lucas Generator and Control Box tests" that you can download from:
https://docs.google.com/leaf?id=0B2H2NJt3...hYmRl&hl=en
M
Member 10617
I am gradually having all the guages rebuilt. I have just had the temperature guage rebuilt; the tachometer will be next on my list.
M
Member 10617
Randall,
Many thanks for the information and advice. When I was having trouble yesterday, the light came on an stayed far too long. Then it started coming on at totally unexpected times, like when I was doing 55 mph. That's when I went to the shop and they replaced the regulator and the generator (which, though brand new, was dead!). Now the light comes on at a normal 9for me) idle, but immediately goes out when I accelerate and stays out until I idle again. I will check out the Box test. Many thanks.
TR3driver
One of the duties of the control box is actually to limit the output of the generator to what is safe for the generator. I learned the hard way (many years ago) that trying to cheat by turning the regulator up a bit is likely to lead to thrown solder and a useless "new" generator.
I only wish I'd figured that out sooner, BEFORE I'd burned up 3 or 4 of them!
:laugh:
Still makes me nervous any time I see over 20 amps charge on the ammeter; but it's OK for a short time after the engine is started (and the generator is cold).
M
Member 10617
Oh... yes... one more twist to this tale. Someone in years past switched the covers to the ignition warning light and the turn signal light bulbs. So, I get yellow when the ignition warning light comes on and red when the turn signals come on. Fixing this would be simple enough if the heater were not in the way! With the heater installed, there seems to be no way to get at the lights to change them. But... I can live with that.
Andrew Mace
Can you get your hand up there just enough to either swap the bulb sockets or undo the wingnuts and pull the center panel forward (to swap the wingnuts)? It's been many, many years since I've done this on a TR3, so I don't remember how easy (difficult) it might be!?
martx-5
Actually, getting the center panel to pull out to get to the back of it is not that difficult. There are four wing nuts. The two on the bottom have to be removed (easy to get to), but the two at the top need only to be loosened enough to pull the bottom of the panel forward to clear the studs, and then lowering the panel enough to clear the upper slots in the dash where those wing nuts are. In other words, the studs in the top do not go into holes, they're in slots. You may have to remove the glove box to get to the upper one on the passenger's side...I don't remember. But that's not much of a job.
angelfj1
Somewhat off-topic, but related, I installed an intermediate terminal strip which allows me to pull the center panel out and easily access all of the main circuits. if you look closely, you can see the rare-earth magnets epoxied to the terminal strip, which is simply held by magnetic attraction to the bottom of the scuttle vent sump.
Geo Hahn
martx-5 said:
Actually, getting the center panel to pull out to get to the back of it is not that difficult...
Though you may also have to undo the line to the oil pressure gauge -- I know mine doesn't have enough slack/flex to allow the center panel to move very much until it is undone.
Just don't start the engine until the line is reconnected!
angelfj1
The simplest way to describe the function is that the ignition lamp "looks at" the voltage difference between the battery and the generator.
TR3driver
Also don't lose that sneaky little leather washer.
However, my recollection is that there is enough room behind those lamps to pull the sockets out and down, even with the heater installed and the panel still screwed to the dash. You have to work mostly by feel, but I'm sure I've changed the turn signal bulb on a car with a heater, without doing any disassembly.
But since the heater was optional, and never did do much good anyway (IMO), I just took mine out and left it. No sense hauling the extra weight around all the time.
HerronScott
LexTR3,
Where in Virginia are you located (is Lex your name or are you near Lexington :smile:)? Also, curious what shop you are using?
Scott
M
Member 10617
Thanks a million for all the good advice and guidance. I think I'll let the experts work on changing the bulbs when the car goes in for its winter tune-up and other work. At the same time, I am thinking of having some of the old wiring upgraded and the tachometer rebuilt.
I am located in Lexington, VA, and the shop I use is located in Waynesboro, VA.
By the way, I have always heard that the TR3 heaters were about as warm as a puppy's breath, but not mine. In the middle of winter, with snow all around and temperatures way down there, I had to keep reducing my heater because it put out so much warm air. In one case, I even had to turn it off. My car, on the other hand, was a normal 185 degrees. This was one of my pleasant surprises with the car.
HerronScott
Ah, Mike Gassman's shop (I live "next door" in Staunton).
Mike and I used to hang out in our "youth" when he had just finished his 1969 TR6 and I was starting my TR4A.
Scott
Cappy Ignition Warning Light Austin Healey 6
T Ignition warning light remains on and headlights come on Austin Healey 8
W Ignition Warning Light Austin Healey 6
M Ignition warning light? Spridgets 14
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
Kurtis TR4/4A TR4 Ignition Warning Light Triumph 6
O Key in Ignition warning buzzer Triumph 5
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
