BoneIdle
Greetings all!
I am attempting to replace the ignition switch on the GT since it no longer functions correctly.
I've run into a problem: removing the cylinder. I know ( after searching here ) that it should be possible to remove just the cylinder, but I'm stumped.
I removed a set screw on the bottom of the assembly, which permitted detachment of the connector, but I can't find a similar screw holding the cylinder in place.
Can someone clue me in? Is there a way to do this? Is there a set screw? If so, exactly where is it?
Thanks!
Garry
Thanks!
Garry
