Ignition problem
ekamm
Well I was taking the tr3 out for a spin, wanted to see if wheel balancing had fixed my shimmy problem and no luck. Ran the car for a while all is good. I stopped the car to pick up my daughter. Then turn it over and it cranks but won't start. First engine problem that I have had since I got her going in Aug.
No spark, everything else seems well. The only thing I have changed recently is turning the timing advance a little to try to see if I can get a little better acceleration. Where would you start?
DougF
The first thing I would check is electrical connections. Both the coil wire and the jumper wire from the coil to the back of the distributor. Also check the jumper for any breaks or cracks.
Next, I would check the rotor to make sure it is secure and in good condition. Newer rotors have had problems with the rivet connection.
If you have a Pertronix set up, the jumper wire will have been removed.
ekamm
ekamm
I used a electronic, pen type spark indicator. (It tried to fire once and thr pen lit up but that was it.) Wiggled every thing nothing obviously wrong. I have power 12 v to the coil. Looked at the points , all looks normal. new rotor also looks good.
ekamm
ekamm
At this point no spark at plugs, smells flooded after cranking and won't fire with starting fluid. Going to work on it later this morning will attempt to set timing. I have another coil but kinda doubt that to be the problem.
angelfj1
Eric: If this is the original ignition set up, underneath the distributor cap are a set of points, a condenser (capacitor) and a rotor. Do you have a simple electrical multimeter or a test light? If you do you can test for voltage at the points when you switch on the ignition. In fact you can simulate the operation of the points by opening and closing them manually. If you have voltage and you open and close the points you should produce high voltage and hopefully a spark. If not you may have a bad condenser. Change out the condenser and try it. if you still get no spark, you may have a bad coil. There are really no other reasons for no spark.
If you have an electronic ignition, follow the manufacturer's directions for troubleshooting.
Here are some guidelines from Lucas.
Good luck.
tdskip
That is good info from Poolboy (as usual).
Eric - if she isn't getting spark at the plugs cranking her over isn't going do anything except drain the battery. Let's focus on why no spark and then go from there.
Is there power from the coil to the distributor?
ekamm
ekamm
Thanks for the info. The car isn't here I will go through every thing and let you know.
ekamm
ekamm
Well so far I've worked my way to the condenser and I'm waiting for it to be dropped of at he parts place.
Adrio
one thing that has happened to me is (with a poor quality points) the "plastic" follower on the dizzy cam wore down. The result is the point gap decreases to the point where they don't open any more. No point opening equals no spark. Check to make sur the poionts are opening and closing as the engine is cranked. Easy to do with the dizzy cap removed.
angelfj1
Adrio: That's interesting. But how many miles before the cam follower is shot? A small smear of lithium grease on the cam lobe was always recommended.
ekamm
ekamm
OK here's the scoop .As I suspected from the start it was a timing issue. I guess since I had never dealt with it before I was apprehensive to change it. No spark, not because of an dizzy issue but not timed = no spark. I looked at a few different timing approaches, none of them seemed to do the trick. So with the help of a buddy did the old you crank it and I'll turn it (the dizzy) and she fires right up. Turn it back and forth a little till it sounds good and tighten it down. She's running great! Thanks for all the help, any knowledge is worth having.
D Ignition problem or not ? Austin Healey 11
J TR6 Electrical ignition problem Triumph 9
TulsaFred Ignition / Ignition coil problem Spridgets 10
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
5 TR2/3/3A TR3 electrical problem ignition or generator??? Triumph 12
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
M TR6 1976 TR6 Ignition problem Triumph 6
Jim_Newman Pertronix + MSD ignition problem Austin Healey 6
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
6 Oily Ignition Problem Austin Healey 2
jaegzie Ignition/Wiring problem. Spridgets 11
Got_All_4 TR2/3/3A TR3A Ignition Problem / Question Triumph 11
7 Ignition problem Triumph 10
R Wedge TR8, ignition switch problem? Triumph 4
D ignition problem Spridgets 4
A Austin 10/4 ignition problem. Other British Cars 5
eejay56 78 Spifire ignition problem Triumph 24
ObiRichKanobi Mysterious Ignition? Problem Triumph 19
L Bugeye Ignition problem Spridgets 12
S Need help with ignition problem Austin Healey 4
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
