Idle Too Fast
NutmegCT
My two cents: why not disconnect the linkage piece by piece, until you find the part that's binding. Note also that heat builds as you drive, so what is loose on a cold engine may be binding after driving a bit.
And you did check the pedal linkage where it enters the firewall, right?
Tom
TR3driver
Great Pumpkin - R.I.P
Oh darn! For some strange reason, I was thinking of H6 carbs, but of course your 4A has HS6. So of course pushing on the idle stop screw did nothing, yours are attached to the body instead of the throttle shaft like mine are. Sorry, I'm not going to be much help. But, now that you can see the problem under the hood, it should be easier to trace it down. I believe there should be just a little bit of play between the lever on the left in your photo with the pinch bolt and the actual throttle lever to the right.
KVH
KVH
That's a great idea! I deliberately snugged the linkages before tightening the balancing screws so that there is "zero" play between the foot pedal and the carb linkage. I'm going to try leaving some play as you suggest. That just may be the problem after all. In fact, it's only 9:00 o'clock, and I may try that before midnight.
TR4A_IRS
I, too, have an engine that doesn't like to come back to idle. With my car, I am 99% certain it is binding at the lever (Moss part no. 373-385 for reference) on my rear carburettor. The lever, and other associated parts, are fitted to the throttle shaft and slide over a flat on the shaft. There is a nut that tightens the lever to the throttle shaft. If the proper bush, through which the throttle shaft is inserted, is not used (too short, for example) of a washer is omitted (my problem) the lever can easily bind against the carb body. I figured out my problem because the screw, for the choke, that runs through the lever, doesn't line up properly with the fast idle cam.
A stronger spring had been put in my car by the PO. When I reverted to new, original style, springs I started to experience the problem. I have mitigated the problem through fiddling and lubrication, but I will need to disassemble the carburetor linkage, and reassemble it properly to cure the problem. Too much trouble, to solve a minor annoyance. A stab of the throttle returns me to idle, and I could always use stronger springs, i suppose.
As others have mentioned, I would check each linkage and look for what is binding, as surely something is...
BTW, your linkages and associated hardware look beautiful. Where did you get the parts?
NutmegCT
And the result is ... ?
Inquiring minds want to know!
Tom
PS - just to clarify, are you saying the engine speed *increases* to a high rpm? Or just that it *sticks* at a high speed. Your original post said "Suddenly 1800 RPMs at every stop light;"
KVH
KVH
OOPS, that's just a stock file photo--not mine. Also, just to clarify--my throttle sticks, and doesn't speed up, though it sure seems like it at times. I "corrected" my post above. No matter how many times I proof read, I still . . . .
KVH
KVH
Just to cap this: Got it fixed finally; I added a stronger spring to the accelerator shaft, greased everything again and left some deliberate clearance in the levers per my pic above. Finally!
NutmegCT
Congrats on the improvement. To help others with a similar problem, could you point out where that "deliberate clearance in the levers" is?
Thanks.
Tom
KVH
KVH
Too quick to celebrate. Here it is just a few days later and I've got a fast idle problem again, maybe worse than ever.
I've looked at virtually everything I can think could be the problem. Idle comes down each time I flick the gas pedal.
I centered the jets, and I doubt either jet needle is bent. The pistons rise and fall neatly. All linkages clean and greased.
Doesn't it have to be something loose in the butterfly at this point?
Could it be that I just don't have the pinch bolts tight enough on the connecting shafts between the two throttles or is that irrelevant to the issue? Could something be slipping, allowing a butterfly to stay open?
Anthing else come to mind that I may be overlooking?
NutmegCT
Did you disconnect the gas pedal linkage, to see if the "sticking" is in the bushing at the firewall?
I'd sure try to isolate the sticking before I took the carb apart.
Tom
KVH
KVH
Sorry for all the dramatics. Now I've got it fixed! Guaranteed. I'll post a pic and explanation.
KVH
KVH
This issue wasn't nearly as complicated as I made it. Over the past two weeks, I bought new springs, oiled and greased everything, centered the jets, added a new foot pedal return spring, adjusted the mixture, balanced the carbs, and on and on . . .
Here is the primary cause of all of my problems with a racing idle on my HS6 SUs:
Somehow the linkage must have slipped after getting hot (this started after a long idle where the temperature approached 190 degrees or higher). In the picture you can see the lever fastened with a pinch bolt fitting, and that lever, one on each carb, has a small barrel stud marked in RED that fits in the "saddle" of the throttle "lost motion lever" which is Moss part 372-840.
In all my maneuverings and adjustments, I balanced my carbs by loosening the pinch bolt, and when I re-tightened the pinch bolt I deliberately set the barrel at the bottom of the saddle so that there would be no delay or "play" when pushing the gas pedal. The problem was that the barrel was not allowing the throttle levers to return fully closed.
Last week I thought I'd fixed this by floating the barrel smack in the middle of that saddle (the lost motion lever). I thought that fixed it, but it didn't.
Today, I noticed the problem with my idle racing at 1900 rpms. So, I loosened the pinch bolt, rebalanced the carbs, and then made absolutely certain that upon re-tightening the pinch bolt on the levers (Moss part 371-860), that barrel on the pinch bolt was pushed to the very top of the saddle in the lost motion lever. That way, the barrels push the butterflies shut. In other words, the springs pull the levers up against the saddle, forcing the throttle levers to close fully. The idle is where it should be.
You can see that in the picture (which I edited for clarity after my initial post).
You'll note at least three levers in the Moss drawings: Throttle levers, levers next to the throttle levers, and lost motion. I have a hunch that "lost motion" may tell the story of what I went through.
Sorry for the long opera. I hope someone else will benefit from the above.
NutmegCT
Hey - congratulations! Good job of troubleshooting.
"This issue wasn't nearly as complicated as I made it"
I know those words very well ... like when I spent almost an entire month trying to get my 1960 M-B engine to run - and the problem was just a loose terminal on the wire between coil and distributor. Oy.
Tom
vivdownunder
An extra return spring is a common way of improving return to idle. It's usually fitted horizontally between the bellcrank (under the carbies) and the sliding bracket on the dynamo.
Often the bellcrank pivot pin often misses being lubed, causing elongation of the ferrule on the pin. Throttle response becomes slightly delayed until the slack is taken up.
Viv.
HalLucy Post-War Other Renown - Idle too fast Triumph 5
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Rick60 Setting up Carbs/slow idle too fast Austin Healey 5
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
RJS Idle too high Triumph 9
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
crispy Idle Speed Variation Austin Healey 19
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
S Can’t get idle speed below 1300 RPM Austin Healey 28
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
NutmegCT T-Series MG TD idle speed? MG 12
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
wkilleffer MGB Air leaks and fast idle speed MG 11
Marla TR4/4A Idle spring? Triumph 7
D 69 E Type High Idle Jaguar 9
K TR2/3/3A Mild street cam and Idle? Triumph 13
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
J MGB Project car done: idle variable MG 2
J SU HD6 - Slow Idle Screw Austin Healey 13
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
S Idle falls until car stalls Austin Healey 10
steveg HD8 high idle aggravation Austin Healey 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
