Ok I cleaned the jets, made sure the wires were at 1342, made surefuel pump was pumping. I started the car. It runs at 1500 with full throttle, and no choke, let off the throttle and it dies. The plugs after it runs and black. What the heck is wrong here.// As I said before the carbs seem to be functioning as they should, and the butterflies open and close freely. I pulled the valve cover and all valves are opening and closing freely. No vacuum leaks either. I somehow do not think itis valves as the car was running before. Can the ditributor go in wrong, can the timing be that far, off I am guessing now..... /ubbthreads/images/graemlins/cryin.gif
