Ideas on getting this bolt unstuck
tdskip
On the '74 TR6. Figured might as well pull it and get it rebuilt while I wait for the spacers. I've tried a breaker bar on it and it felt like it was going to snap, which would stink.
FYI - got the new TRF motor mounts install no problem, and with a bit of coaching from Bill I have good clearance for the fan belt now.
TR4nut
Tom--
Something bad happened to your photo link, it isn't there anymore.
Not sure what kind of bolt problem you have, but I still swear by the trick another BCFer or team.net-er talk me a while ago: localized heat, touch stud with a candle to draw wax into the threads. I've been able to pull several snapped studs with that method without fail.
Randy
TR4nut
Tom-
If I have the picture right, isn't that a very long bolt, say 5-6" holding the alternator? If heat can't be used, I'd hit the back part with PB Blaster, let it soak away - and can you possibly get an impact wrench on it to try to jar it a bit?
Randy
mailbox
You might could cut the head off, remove the alternator, THEN try the wax thingy trick (never heard of that. WILL have to try.)
tomshobby
The wax trick is something the old timers used in the days when very few home shops had air tools. It was used a lot on bolts or plugs threaded into castings. Now days a lot of candles are not made of wax or paraffin which is what works best. Doesn't need a lot of heat and works surprisingly well.
T
tdskip
Actually the bolt extends all the way through to the other side, so it is a good 12 inches or so long. It passes through the mounting and spacers and comes out the other. Very different mounting than the 1971 TR6.
DougF
After soaking it, try tapping the spacers from various angles with a hammer. If electrolysis has formed between the alternator body and the capscrew, this might be enough to break it up.
T
tdskip
Hi guys - well I tried rapping the spacers with a hammer, more soaking, heat, more soaking and no dice.
Funny how this was one thing that I was not worried about...
DaveatMoon
It looks like you <span style="font-style: italic">might</span> be able to get a hammer and impact driver in there. :hammer: Even if you have to pull the radiator and/or grille to do it, it would be better than breaking the bolt. An impact driver might help shock the bolt loose after a good overnight soaking in PB Blaster. Mine has saved my butt more than once! :smile:
T
tdskip
I think I'm heading that way - which is annoying because I just put the radiator back <span style="text-decoration: underline">in</span>.
mikespain
You might end up having to carefully cut the bolt between the spacer and the alternator mount at the front and back(hacksaw blade),remove the alternator and then if the bolt is seized on the threaded part in the alternator it will be easier to work on and extract on the bench or if it is seized as it passes through the block it can be soaked and coached out with 'ammer and drift heat etc,just make sure you cut on spacer side ,theyre cheaper to replace than the alternator brackets,possibly easier and quicker than removing rad etc and then finding the bolt still shears.
K
KSIS
Tom,
I had a similar issue on my sons VW GTI. The allen head stripped. We cut the head of between the spacer and the bracket, bent the altenator up out of the way and slid it of for room to work. We cut the bolt in half, then cut a notch in the threaded end. We use channel locks on one side and a screw drriver on the other. We both took turn twisting and the bolt slowly came out.
PIA factor, about a 7, but it worked.
I would go the first route and spray woth PB Blast. Our solution was a last resort.
BobbyD
If I'm understanding this correctly, you got the nut off of the bolt but the bolt is frozen inside the alternator or the spacer. I've got a GM alternator but I've reused all pieces that you have, just in a different order. The picture below gives a good view of the areas where it can be bound up. How about going the other route and remove the bracket from the engine (two bolts) and take the alternator and bracket off as a unit. Then you could work of it while off the car. BFH, PB Blaster, Heat, Impact wrench!
TR3driver
Great Pumpkin - R.I.P
Faced with a similar problem on my TR3, I wound up drilling the bolt after cutting off the exposed end. Bolt was 3/8", so I used a 1/4" drill bit and went in as far as I could before the hole wandered to the side of the bolt (as evidenced by getting rust out with the swarf). Then I shot some PBB down the hole, and turned the head; the mangled bolt came right out.
T
tdskip
Thanks guys - I think pulling the mounting bracket to remove the unit as a whole so I can then beat the stuffing out of it is a good idea. I'm expecting that I'll be sectioning the inner bolt and breaking out the drill as well.
Also seems like this is a hint that it is time to go with an upgraded alternator...
I had such a simply plan - rebuild the suspension and then just drive her as is (ie rolling ugly) and enjoy the season. The phrase polishing a turd comes to mind here - LOL. (I bought her like this, so no complaining)
T
tdskip
Wait - I can't remove the mounting bracket because the bolt runs through a plate which is attached to the engine front cover. That thin plate that runs down near the middle (middle arrow on the right side just touches it) will prevent me from removing the mounting block. Bummer.
I have managed to get the parts with the red arrows turning now, so the bit locking it in place must be in the long middle section in between the two most right red arrows.
TR4nut
Oops! I take back Bob's reported victory!
Have you tried this: put the rear nut on loosely to just protect the threads - then hit that forward with a hammer. Don't think there is much you can damage with that operation, and it might at least break the rust bond.
Randy
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
