jlaird
I need to bleed the brakes again. I noted that the fluid resivor was down, no leaks that I can see and the pedal is just a bit better after one pump.
Going to pick Miss Agatha up tomorrow and double check fittings along with a bleed.
Will also pull the tac drive cable an put a bit of grease in there as well, think it is binding a bit and causes the cable to kind of thump around under the dash.
Still not real happy with the carb settings, seems to be a bit lean still. Will keep messing with them. Good reason to keep taking Miss Agatha out for a short run. I know I should be able to tune the carbs in the driveway but I seem to have lost the touch.
Off to the Bay British Car show in Panama City. Miss Agatha says she does not want to go till she is ready, I mean really ready. She misses her headlights, grill, and seats, hehe.
Guess I am going to have to spend some serious money soon and get this kind of finished up so she can be registered and such.
