jlaird
Not quite sure where I go from here.
Engine starts fine and wants to race.
Then drops off and quits.
Seems like I have been through this before. But I can adjust idle at this point.
Just do not know where to go from here. No clue, not even a bad idea, throtle bearings are tight, no movement at all. So I have a hard time beleiving air leaks there. No fuel leaks anywhere.
Chokes are all the way in, no prob there. they are up in the carbs properly, oil in the dash pots, flats at 9. Timeing changes make no difference.
Guess maybe the answer is new carbs, H2s if I must now. Will mess a bit more but seems hopeless.
Wish I had a pair of running carbs from someone close by that I could just throw on and test. I am out of ideas.
