TR2/3/3A Hub extension torques? [for wire wheel]
GTP1960
I have replaced my hub extensions for wire wheels, but can't find the recommended torque in the workshop manual.
appreciate your input.
Guy
attachment.php
TR3driver
Great Pumpkin - R.I.P
65 ftlb per the TR4 workshop manual.
GTP1960
GTP1960
Thanks Randall,
bad tires> lead to new vredsteins >lead to new wire wheels> lead to new hubs.
the silver lining is that it's my wife's Birthday!......hope she like the new tires/wheels as much as I do!
Geo Hahn
Glad to see you got them (that one anyway) on the correct side of the car.
More than once I have convinced my wife that our upcoming anniversary is 'car parts' or 'tools'. At least I think she was convinced.
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
G TR4/4A TR2-3B Hub Extension Triumph 6
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
B Rear Hub Extension Studs Austin Healey 22
Rob Glasgow Worn Hub Extension Studs Austin Healey 2
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
richberman torque for hub extension nuts? Austin Healey 3
Bremer TR2/3/3A TR3/4 fan hub extension elimination kit? Triumph 3
K TR2/3/3A TR3A Splined hub extension picture? Triumph 4
sjuengst Hub extension retaining nuts Austin Healey 10
J TR4/4A TR4 Fan Hub Extension replacement Triumph 4
tony barnhill Rear Hub to Wire Wheel Extension Question Spridgets 3
Tinkerman TR2/3/3A Fan to Fan Hub Extension Torque Data TR-3 Triumph 5
T TR4/4A TR4 Engine - Fan Hub Extension Triumph 4
mctriumph TR2/3/3A Hub cap emblems Triumph 2
D Removing the steering wheel hub Spridgets 12
Carlbanan56 MGB Front hub MG 4
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
B TR4/4A Steering Wheel Hub Issues Triumph 0
M T-Series MG TD 1st/2nd sliding hub end play MG 1
A BN7 Front Hub Stud Nuts Austin Healey 5
Lin Bugeye Axle Hub & Bearings Austin Healey 1
AUSMHLY Synchromesh Hub End Float Austin Healey 1
W Rear Axle Hub Seal Austin Healey 8
R TR2/3/3A Steering wheel hub removal Triumph 11
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
W Rear Hub Reassembly Austin Healey 7
A Later drum backing plates - hub not clearing Spridgets 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
K TR2/3/3A Front Hub and Felt Seal Triumph 1
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
M Spitfire Triumph spit flange/hub removal Triumph 13
Got_All_4 TR6 Differential side hub measurement Triumph 1
B Wanted Hub Austin Healey Classifieds 4
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
K For Sale TR3 Hub...short studs Triumph Classifieds 0
Rob Glasgow Rear Hub Nuts Austin Healey 11
B TR4/4A 3rd/top gear syncro hub Triumph 2
Sopwith_Camel hub of the action Jaguar 5
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
