eschneider
hs6 "414" needles - 2000 rpm idle
Just rebuilt a pair of hs6's and can't get the idle to come down below 2000 rpm with the throttle controls disconnected the idle screws not touching the stops, choke disconnected, and the carb-to-carb shafts loose
Yes, I'm checking the throttle plates, vacuum leaks, jet centering.... I may have *slight* leakage at the throttle shafts, but.... 2000 RPM????? I would think a vacuum leak would just make it run crappy....
Question: the kit had needles marked "414".... needles that came out of the carbs were "TW". What the holy heck is a 414? Checked it with the vernier calipers and they seemed to be comparable, but it's bugging me. I couldn't find any info on them.
