RichBall
I'm hoping someone would be able to take a measurement off of an HS2 and an HS4 for me. I'm looking for the length from the center of the throat to the bottom of the float bowl.
Just to satisfy my curiosity has anyone tried using twin HIF4's on a 1500? I know you can use the HS2's from a Spitfire and that the HS4's can be used but requires some cutting of the foot well. So the other day I was roaming the wrecking yard and came upon a '77 MGB with HIF4's and it got me to thinking. If the bowls on the HIF4's was shorter than the HS4's then maybe they could be used. The measurement from the center of the throat to the bottom of the bowl on the HIF4 is 3.4 inches.
Just a thought.
Just a thought.
