twas brillig
We've had an Austin-Healey 3000 for over 40 years but only started driving it (sporadically) in the last five or eight. Did a compression/leak down test on it 18 years ago and all was good; did a compression test last week (one bad cylinder 60 psi) and a boroscope inspection Friday. No piston or valve damage, but seemed to be a lot of scoring on the cylinder walls. We'll be looking at a rebuild (or sale some day with engine as is, with a heads up, as it runs okay). But! Why the scoring?
I'm guessing that the infrequent starting means that the cylinder walls would be truly dry and no lubrication. Thoughts? And if you store a vehicle and don't start it for - say - six months (we get winter and gravel on the roads in Calgary, and store it in a Car Capsule so can't really fire it up every two weeks), what should one do when summer doth come?
I"m posting here and the Healey site because we have a bugeye that we've stored for over fifty years (plan is to have it on the road next year; did start the engine this past summer) as well as one that we've driven off and one for years, but not for the last five. So those motors would be exposed to the same issues.
My thinking:
- for the first tank of gas in the warm weather, throw in some traditional two stroke motorcycle/small engine oil. Use the recommended ratio on the jug. Dunno how badly that'll smoke and pollute
- pull the plugs and squirt some (a tablespoon? (whatever that amounts to)) into each cylinder. Regular engine oil or the two stroke again?
- just generic: we've been doing very little mileage per year. Different folks change oil for different mileages (3000 miles? 5,000 miles?) but what is the general feeling as to the mileage that warrants an oil and filter change before parking it for the winter? If the car's had less than a thousand miles on it since the last change, I'd be inclined to leave it. But -are there any guidelines on this? Any purpose to just changing the filter?
thanks, Doug
My thinking:
thanks, Doug
