As you can see below, I found the shifter bushings that were missing.
Anyone know where I can purchase a new circlip, or what size to get, so that I can reuse these if possible?
The real question is how does one go about removing the lever control? I have removed the stop bolt (loose in photo), and cleaned all the gunk from the threaded end on the exterior of the transmission cover.
Using a threaded bolt into the end it does not slide out easily, so I stopped. Any suggestions on how to remove it so I can have the lever control machined and reinstalled?
The worst part of the job was the dowel in the bottom corner which didn't want to release the cover at all. Other than that it went well.
Patrick
P.S. I've looked in the service manual in the gearbox section as well as looked through Randy's pictures, and could not find the answer there.
Patrick
