How to: Brighter gauge face with LED’s.
B
BUNDYRUM
Hello dar100,
I bought my LED's and the flasher canister from SUPERBRIGHTLEDS.com
The flasher canister is orange in color so I painted mine black.
When you compare the new electronic and original canisters 2 of the 3 pins that the wires hook up to have the same letter designation so it's not difficult to work out which pin matches the remaining one.
The bulbs are the standard 1157 for the original double filament type and the 1156 for the original single filament type.
They have the same bayonet attachment as the original bulbs with the offset pins which means they go straight in.
bundyrum.
AUSMHLY
AUSMHLY
Hello Ed,
My bad, sorry.
Yes, it is the 5 O'clock position, front reading, on both gauges.
Especially on the Speedometer. Placing a light at 7 O'clock and the light will beam through the bottom counter. Does not happen when the bulb is at 5 O'clock.
Looking at the back of each gauge, place the bulb to the left of the stock black plastic bulb holding tube. Measure twice, cut once. Make sure you leave enough room for the socket base.
Happy motoring!
Roger
Ed_K
F.Y.I.
If you install a Tridon EL13 turn signal flasher , the dash turn signal indicator LEDs work without the " bleed over " to the opposite LED. There is no need to use the resistors.
You will have to make a mounting system for this flasher as it doesn't have the mounting tab with hole as the stock flasher has...
It has been great being able to see all of the gauges and indicators, even in the daylight this year ! Thanks again Roger.
Ed
AUSMHLY
AUSMHLY
Wow a blast from the past is this post.
Hi Ed, thanks for sharing.
Ed, could you provide a link where to purchase the Trident EL13 signal flasher?
Ed, did you add an additional led to the bottom of the speed and tach?
Some upgrade projects I really enjoyed doing. This was one of them. The led's helped us see our gauges much better at night. My surprize came with how well the led lit up the directionals in daylight. It's a real help, in case you can't hear the flasher unit (who can hear it?) and the turn lever does not return to off. Now, in daylight, you can see it's still flashing.
Happy Healey motoring,
Roger
GregW
Platinum
Hi Roger,
I guess your next fun project will be to fix the trafficator. :laugh:
AUSMHLY
AUSMHLY
Hi GregW,
Been down that road already. Yup, took it out, took it apart, fixed it. Works like a charm now!
Just pointing out, that for those that have a trafficator that does not work consistantly, the led will let you know, in the daylight, hey....your blinkers still on.
Greg, I've got other secrete upgrades on working on. :wall:
Cheers,
Roger
AUSMHLY
AUSMHLY
Thanks Ed for turning us on to the Tridon EL13 turn signal flasher.
My led directional had the bleed over you speak of. Every now and then I said I will look into it and fix it.
So today (because of your post) I went to NAPA and they cross reference the Tridon EL13. Yup, they carry it in their brand. Their part number?...EL-13. How about that. So, if anyone wants an electronic flasher that will stop the led bleed over, NAPA carries one too. And here's the really good news, which is written on the package...Extended life, lasts 10 times longer than thermal flashers.
Reproduction thermal flasher from the usual supects $23.00
NAPA electro-mechanical flasher $11.89
Looks like this flasher may outlast the Healey!
Cheers,
Roger
TomFromStLouis
I am glad this thread is revived because it reminds me that I never scored any LEDs. The source listed above for the positive ground situation ((12) BA9s bayonet HID white high power led bulbs) was out each of the three times I contacted them, so I am open for suggestions.
If anyone can offer a response, please type it very slowly, because electrical matters confuse me very easily.
I cannot even remember if this was the one they did not stock: https://www.v-leds.com/Shop/Control/Product/fp/vpid/6057628/vpcsid/0/SFV/32481
Does that look right Roger?
AUSMHLY
AUSMHLY
Hello Tom,
I tested a lot of different styled LED's.
The led in the link you provided is not the led that worked as well as the BA9S 1 Watt High Power LED Light.
You'll see from the 1st photo below, how wide the light is dispersed. Most led's like to focus the beam forward.
The one in your link, 2nd photo V-LED's...although it dispersed the light pretty good, didn't work as well overall. Certainly not as bright as the 1 watt style.
Try this link.
https://www.ledlight.com/ba9s-1-watt-high-power-led-light.aspx
Cheers,
Roger
AUSMHLY
AUSMHLY
An alternative:
It does take a bit of work to islolate each LED for a positive car.
However, if you want a easy fix to increase the light you have now, I can offer an alternative way.
Replace the 2.2 watt screw bulb in the fuel, and the water/oil gauge with a 5 watt. That will light them up really nice. I tried an 8 watt and it got too hot.
Remove the speed and tach gauges. Gauges facing down, drill one hole in the now back of each gauge. The hole will be to the left of the long black plastic tube (facing 6 o'clock) that holds the light bulb for the high beam on the speed and the red charging light on the tach.
That hole size will be to accept another 2.2 watt screw bulb holder.
Now both the speed and tach will be lit up evenly, top to bottom. It will make a big difference.
Two 2.2 watt fillament bulbs will illuminate the gauges much better. It will also keep the warm light color vs the blue/white color an LED provides. (just for reference, in case your looking to keep the stock brightness color/hue).
I would spend the time to isolate and install one led for the high beam, charging light, and both directionals. Led's are the only way to go there. You want that light as bright and focused forward as much as possible. LED's are much better at that.
Let me know if I can be of any more help.
Roger
theleisure
Bronze
i just tried to replace the 12v 2.2w ignition light bulb with the e10 superstar you recommended. There's a problem-- the light doesn't light up and stay illuminated when the key is turned to the on position, it only gives a tiny flash when i turn the key from on to off. i never started the car through all of this mind you...
what do you suggest i try next?
healeynut
The one circuit that won't work with the LED is the ignition light circuit. LEDs are either on or off. There is no in between with an off the shelf LED.
Your best option with this bulb is to switch back to your old 2.2w bulb.... :frown:
davidb
You are a wizard - the Wizard of Aus.
Now do you have any "bright ideas" on how to fix the economy?
Cheers
Dave
AUSMHLY
AUSMHLY
Sean, try what I did below.
My car is negative ground. I am using the E10 Superstar led as the ignition light bulb. No problem. I turn the key to the on position, with out starting the car, the Superstar led lights up the red ignition and stays lit. When I start the car, the led will fade out, when the car gets up to idle speed.
Here is a photo of the led and a link to where you can purchase it.
1449 E10
https://autolumination.com/otherleds.htm
If the above does not work for you, then you have a problem somewhere. I'll try and help you fix it, as I'm sure others here will also.
Cheers,
Roger
Keoke
Yep, Roger. his problem could be as simple as a bad led.---Keoke-- :smile:
theleisure
Bronze
1449 E10
Cheers,
Roger
I must have a problem somewhere, or a bad E10 Superstar perhaps. I bought 8 of them from the site you mentioned so I have a few extras. I'll take a few bulbs out to the car today to try them and report back later...
Thanks,
Sean
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
edkap2002 TR6 Brighter instrument lights? Triumph 0
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
I Solution for brighter dash lights? Triumph 14
T BRIGHTER DASH BULBS.......anyone have numbers Spridgets 10
PAUL161 Brighter Lights-[Cheap] MG 1
healeyboz brighter side of things Spridgets 7
A brighter light... Triumph 15
G Rear lights brighter than ever.... Triumph 1
Brosky Brighter dash light bulb saga continues Triumph 17
A Brighter Smiths Instrument Bulbs --- Any ideas? Austin Healey 25
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
B For Sale BaulyCars - Gauge Bezels Triumph Classifieds 0
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
